Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best riding suspension for 1927 Ford Roadster
  #20 (permalink)
Old 09-12-2018, 06:10 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
Originally Posted by bubbamace View Post
Thanks, RWENUTS. You and the rest of the guys believe the front shocks are the problem Im going to look at these, the angle and the length and attempt to fix them. I really think I should think about raising the whole car. Its too low and I think that limits the suspension.
I donít know about your shocks but your shackle angle is the problem. When the spring compresses it gets longer and the shackles bind up solid. Shackles are supposed to be at 45 degrees so they donít bind when they flex closer to vertical.
The Following User Says Thank You to RWENUTS For This Useful Post:
bubbamace (09-12-2018)
