Best riding suspension for 1927 Ford Roadster - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2018, 09:17 PM
bubbamace's Avatar
Hi guys. I've got a 27 Roadster that has a straight front end. I guess. Anyway, my roadster sits on the ground. It rides okay on good pavement, but doesn't take bumps or bad pavement very good. I was thinking of selling it because it rides so rough when I hit a bump I'm afraid to take it on the freeway. A guy I met at a car show told me to lower the air pressure in the front and rear tires to 20 psi, which I did. It rides better, but I'm a little concerned about such low air pressure. I forgot to mention the rear has coilovers.
Can anyone recommend a way to make this car ride better ? I like this car and it gets a lot of thumbs up, but its teeth rattling ride is no fun. Maybe all of these old cars are supposed to ride like this. If this is the case and nothing can be done to make it ride better, please just say so. Thanks, Bubbamace.
Sent from my SM-T560NU using Tapatalk
Old 09-09-2018, 10:17 PM
RWENUTS's Avatar
Take some pics!
Of your front and rear suspensions.
Old 09-09-2018, 10:19 PM
39 master's Avatar
suspension
Really need pictures of both the front and rear suspension. A solid axle really shouldn't ride that bad and if you get bone jarring then something is bottoming out. To get the front a little higher you can have the spring re-arched. From a safety point of view this isn't a good idea but take the front shocks off and see if it does any better on bumps. Next, see if you can determine if the rear shocks are bottoming or the springs coil binding. At any rate we still will need pictures.
Old 09-09-2018, 10:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Is there evidence of the suspension or axles hitting the frame. guys build those cars so low and forget the suspension needs some travel to get a good ride.
Sam
Old 09-10-2018, 07:29 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
springs too stiff ?
lots of good info here from Fatman
google
fatman hria hot rod
lower tire pressure improvement means that your springs are too stiff or your shocks are bottomed out. unbolt a shock and check travel, it should be at mid point at ride height. I put a spacer under my T bucket cross leaf springs and tool out some leafs. to get it up and a softer ride.
The Following User Says Thank You to timothale For This Useful Post:
bubbamace (09-11-2018)
Old 09-10-2018, 07:42 AM
bubbamace's Avatar
Okay, guys, I'll post some pictures as soon as I can. Some good ideas here already. I'm thinking that the suspension is so low that I'm not getting much travel in the front. Not sure what the problem is in the back.
Old 09-10-2018, 07:49 AM
bubbamace's Avatar
ID:	434963Click image for larger version
ID:	434961Click image for larger version
ID:	434965 Okay, these were pictures I already had in my camera. When I get back to the house today, I will take some better pictures.
Old 09-10-2018, 08:16 AM
36 sedan's Avatar
20psi may still be too much air, depending on the tire width and the weight of the car. My T Bucket ran 6-8 psi in the rear and 15 psi in the front, any more and it would jar your teeth. Chaulk your tires if you're concerned about wear. Chaulking will show you exactly how much air your tires need to wear flat.
The Following User Says Thank You to 36 sedan For This Useful Post:
Old 09-10-2018, 07:40 PM
bubbamace's Avatar
I'm not worried about tire wear. I was more worried about not having enough air to avoid a flat while out on the road.
Old 09-10-2018, 07:51 PM
bubbamace's Avatar
I don't see any evidence of the suspension hitting the frame or body. I did have to correct the angle of the front shocks when I first got the car because they were making contact with another part of the suspension and almost had made a hole in both shocks. I also added the steering stabilizer which really helped tighten up the steering. Here are a few more pictures of the suspension.
ID:	434989   Click image for larger version
ID:	434991   Click image for larger version
ID:	434993   Click image for larger version
ID:	434995   Click image for larger version
ID:	434999   Click image for larger version
ID:	435001   Click image for larger version
ID:	435003   Click image for larger version
ID:	435005   Click image for larger version
Old 09-10-2018, 07:55 PM
bubbamace's Avatar
I'll have to try less air in the tires. I think the rears are either 10 or 12 " wide. The car weighs about 1800 lbs with me in it. The tires are 14s in the front and 15s in the rear.
Old 09-11-2018, 09:54 AM
ogre's Avatar
the 'Duracell Project'
front shocks look really short, disconnect them and go for a ride
you may bounce all over but it will probably tell you the shocks are bottoming out
The Following User Says Thank You to ogre For This Useful Post:
Old 09-11-2018, 11:33 AM
RWENUTS's Avatar
Your spring shackles are at the wrong angle.
Yours are almost vertical when they should be at a 45 degree angle.
Strange type of coil overs on the back.
The Following User Says Thank You to RWENUTS For This Useful Post:
Old 09-11-2018, 12:40 PM
delawarebill's Avatar
front shocks and pressure
looking at your front shocks u really need to redo that top support so the shock is mid way standing still. u hit a bump and it'll bottom out for sure. as for pressure, buckets don't need a ton of pressure. i think i was in the 10 to 15# area on rears. but mine were 20+ inchs wide.. can't remember now.
The Following User Says Thank You to delawarebill For This Useful Post:
Old 09-11-2018, 07:14 PM
bubbamace's Avatar
Thanks, delawarebill. I'll try to lengthen the shocks by changing the supports. Thanks again for the idea. Bubba
1932 window frame/posts on 1927 Ford Roadster bubbamace Body - Exterior 6 03-05-2018 08:35 AM
Steering rod angle question (PIC) 1927 Ford Roadster jetskibob1 Suspension - Brakes - Steering 4 03-09-2014 09:32 PM
'32 Ford Roadster, best glass body, best frame? Fin Hotrodding Basics 40 01-31-2014 12:37 PM
1927 Dodge Roadster 4 Cyl 1927ROADSTER Introduce Yourself 4 02-13-2012 06:23 AM
1927 ford coupe rear suspension question pi71 Suspension - Brakes - Steering 4 11-28-2007 07:15 PM
