Big Block Chevy Horse Power Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2010, 06:05 PM
d^2 d^2 is offline
Howdy
I am looking at building a Big Block Chevy for my '72 GMC 3/4 ton 4X4 with
factory A/C and posi traction. What cubic inch motor would be best to get
good fuel economy AND horse power? Is it possible to get
good economy and be able to run on pump gas? Will a 396 w/ 9.6:1
compression get better economy than a 454 w/ 9.6:1 compression? How can
I get over 400 horse power out of a 396 w/ a mild cam?
Thanks
Old 12-23-2010, 06:10 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
ive always gone with the bigger the motor is, the less pedal you need to make it go.
Old 12-23-2010, 07:10 PM
You can use a smaller cam and heads on a 454 and get 400hp, the same HP from a 396 will require bigger heads and cam(more fuel use). MPG will be more related to low cruise rpm(overdrive) and good vacuum signal.
Old 12-23-2010, 07:36 PM
& matts38chev
sounds like the perfect time for a peanut port headed 454
and that should be easy to find
Old 12-23-2010, 08:56 PM
Banned
You need to be more specific with your goals/combo. I may consider a stock 454 with an rv cam and headers to be perfect for your application, or a $25,000 very well built and tuned 572.
Desired mpg's? Budget? Truck details?
Old 12-24-2010, 03:31 PM
here you go.
http://www.chevyhiperformance.com/te...ild/index.html
a 385HP 396 build.
do the same with a 454 and make 440hp due to 14% more engine.
I use a 396 and a 454 in my c10 truck (not at the same time). Both engines are built the same way (mild) and the 454 has noticeable more power and gets better mpg (1 mpg better) as compared to the 396.
As for BBC's, I recommend that you build a 454 and use some good cylinder heads.
FYI, good fuel economy and big block chevy don't belong in the same sentence. My 4200 pound truck with a 3.08 gear and th400 trans gets 8 to 9 city and 12 to 14 highway (depending on speed). I would guess a 3/4 ton 4x4 would get 6 to 7 city and 9 to 10 highway with a bbc.
If you need 400hp and good mpg then you would be better off building a late model LS engine.
Old 12-24-2010, 03:44 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Roger that. Start with the larger 4.250" or bigger bore. The smallish bore of a 396 cannot possibly allow the flow that a larger bore can due to shrouding of the valves.
Old 12-24-2010, 06:03 PM
d^2 d^2 is offline
Howdy
Thanks for all them there speedy replies. Would I be better off with a 383
stroker? What type of fuel economy would I get with a 700R4 behind it?
Thanks
Hey, is that a 9mm? That's nothing compared to this 44 magnum.
Old 12-24-2010, 06:54 PM
Wiki Edits: 326
If you ask about fuel economy one more time while discussing big block Chevies and stroker cranks, I'm gonna double up and puke on my keyboard. HOLY JESUS!!!! Buy a freekin' Honda and have it over with. Enough is enough.
Old 12-25-2010, 05:43 PM
d^2 d^2 is offline
Me Like Strokers
P.S.
Send me a picture when you puke
Old 12-25-2010, 06:16 PM
build a 496 torque monster or a 427 screamer. im trying to decide which would be better for my mud monster right now lol have a 427 TD to play with.
Old 12-25-2010, 07:45 PM
Wiki Edits: 49
Howdy
Thanks
So is this the same 396 that you lied about in your other thread?? Oh, I'm looking at buying this motor is it priced right? Then it winds up being your motor and you're trying to sell it in the forums.
Old 12-26-2010, 12:13 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I second the ls motor. The GM 6.0l lq9 makes like 385hp from the factory and I believe the lq4 makes a little less. On that horsepower tv they did a 6.0 with cam and intake and made close to 500hp.
Old 12-26-2010, 02:33 PM
d^2 d^2 is offline
Do the LS's have different motor mounts? Is the bell housing the same? What would it take to convert a truck set up for a normal sbc to a LS series motor?
Thanks
Old 12-29-2010, 09:53 AM
Liar !!!!!
Need small block chevy build ideas would like around 500 horse ssmonte Engine 17 08-03-2011 02:25 PM
horse power torque estiment.72 chevy andrew400tpi Engine 4 11-19-2009 08:58 PM
327 build horse power guestimation inbredjedd Hotrodding Basics 2 07-11-2009 08:01 AM
How Much Horse Power Will I Make 350 Chevy davekreis Engine 5 03-02-2006 05:32 PM
big block buick horse power Al Combs Hotrodders' Lounge 2 05-23-2003 10:17 AM
