Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big Block Quandry
Old 06-24-2019, 08:18 PM
jjjaffo's Avatar
jjjaffo jjjaffo is offline
Thank you. Those images helped. My next question is and Imsport brought it up, which is better, Scat or Eagle for a rotating assembly? I guess my concern is Eagle being made off shore. How are their tolerances and how well do they hold up? Next up is the heads. I plan on buying a set of AFR 290 ovals. I also want about 10.25:1 compression and run pump gas. I believe that requires a domed piston. does anybody have experience with these heads and a particular piston fitting the chamber? Building this engine is a little out of my comfort zone so any info to help me along would be greatly appreciated.
