Big brake discs proportioning valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2018, 06:06 AM
Hi all.
My 51 Chevy truck build is coming along. I put 14 camaro disc brakes all around. I have a Ford Explorer rear end in it. I read about pad bump from the floating axle moving in and out and pushes the calipers in.i bought a 2 lb. check valve from wilwood.
I may be overthinking this but if the rotor pushes one direction and pushes the pistons in on that side then wouldn’t the opposite pistons take up the displaced fluid?
I got a disc from proportioning valve thinking the valve will help apply the rears a little quicker and help with the pad bump. Also bought a wilwood adjustable proportioning valve since my truck is fairly light compared to a camaro.
Anyone have experience on this? Thanks jim
Old 12-28-2018, 12:50 PM
64nailhead's Avatar
Use a disc/disc proportioning valve. Can be found at most every aftermarket brake place. I recently purchased a nice shiny unit from Inline Tube.
brake proportioning valve problem jimfulco Suspension - Brakes - Steering 3 02-22-2009 07:25 AM
Brake proportioning valve problem. ck 2 Suspension - Brakes - Steering 5 09-30-2008 09:38 PM
Brake Proportioning Valve Linkeage Adjustment awbazar Suspension - Brakes - Steering 5 02-03-2006 03:08 PM
Adj Brake Proportioning Valve? sha_ba_do_bang Suspension - Brakes - Steering 7 11-07-2005 01:10 AM
disc brake proportioning valve k-star Suspension - Brakes - Steering 1 01-06-2005 07:00 AM
