Big V12 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2018, 11:07 AM
Big V12
Hi
I got drunk and came home with a Russian V12 of 63 liters.
I need some tips on what to use for gearbox: I had thought about a alleson gearbox. as little electronics as possible
https://youtu.be/TlxG4M5-sMI
Old 01-05-2018, 11:24 AM
bubba1955's Avatar
I suggest you give your liver a break....LOL!!
Old 01-05-2018, 11:30 AM
What's fun with that? Best Buy Ever
Old 01-05-2018, 11:37 AM
Seriously I need help with the drive
Old 01-05-2018, 11:46 AM
Something that heavy leaves you using a semi frame and axles. As far as the transmission same deal Eaton 9 or 10 speed should work.
The Following User Says Thank You to cerial For This Useful Post:
fernballan (01-05-2018)
Old 01-05-2018, 01:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would think the eaton in a heavy truck chassis.. Makes an interesting rat rod if you can keep a trans in it..
Sam
Old 01-05-2018, 01:39 PM
It has been done with 2 stroke 671/871 and such already. It is alot of weight but can also be alot of torque.
The clutch cost alone is nuts and think your on your own with adapters. But that's part of the fun.
I would start with a school bus and cut the thing down to get your axles, fuel, steering, and tons of those little things. Maybe you could beef up the auto(think they slipped from the factory) or just go 9/10 speed.
Old 01-05-2018, 06:51 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Originally Posted by fernballan View Post
Hi
Hmmm I would think that might be a 1/2 case of vodka trade for that monster..
The Following User Says Thank You to Rip VW For This Useful Post:
AutoGear (01-12-2018)
Old 01-06-2018, 05:19 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
This guy could probably give you some pointers.....it's too bad he passed away a few years ago.
Old 01-11-2018, 04:53 AM
64nailhead's Avatar
Hi
I see this thing is rated at 1000HP, but I couldn't find any torque ratings or operating range. I'd have to guess that this makes well into the 2000+ ft/lb range. If you look for an Eaton, then look for 13 or 18 speed with the 1st two numbers of the model number being either 20 or 22. Perhaps a normal 9 or 10 speed would function for some daily driving in a lightweight vehicle, but most all of those that you'll find will be 1250-1650 ft/lb trannies. If the torque is truly in the mid 2000's, you'll be able to snap input shafts and main drive gear teeth at will. You can use a 13 or 18 speed as a 9 nine speed if the operating rpm range doesn't need all of those gears by eliminating the gear split.
If you think you fabrication skills are upto the task, then find a Mack 2050. The triple countershaft transmission is tough as nails and with only 5 gears and really tall top gear it might work pretty well if the operating range is 1500+rpms. They are also easy to repair.
bubba - that's funny
The Following User Says Thank You to 64nailhead For This Useful Post:
AutoGear (01-11-2018)
Old 01-11-2018, 09:11 AM
S10xGN's Avatar
Gotta love a turbo!
EJ Potter?
Russ
Old 01-11-2018, 12:35 PM
Originally Posted by S10xGN View Post
EJ Potter?
Russ
Yes. Although I've never seen this pic of him on the tractor, just broadside photos
Old 01-12-2018, 09:08 AM
S10xGN's Avatar
Gotta love a turbo!
I saw him run his fuel bike at Indy the year before his fatal wreck.
Russ
Old 01-12-2018, 09:56 AM
his tombstone should read "The biggest, brassiest ones of all-time"
Old 01-12-2018, 03:42 PM
poncho62's Avatar
Wiki Edits: 5
Russ
EJ didn't die on the bike......
E. J. Potter, Motorcycle Daredevil, Dies at 71 - The New York Times
V12 55 chevy FASTFORD Hotrodders' Lounge 4 01-09-2016 01:35 AM
V12 Marinizing? flugzoid Engine 16 04-06-2015 12:44 PM
lincoln v12 Chanan Engine 1 01-30-2012 07:26 PM
Mini V12 Irelands child Off-Topic 2 01-16-2011 11:52 PM
Jaguar v12 ? xxllmm4 Engine 5 12-15-2009 06:10 PM
