Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Blow by and engine rattle
Old 11-02-2018, 04:23 PM
MouseFink MouseFink is offline
The engine is worn out and needs a complete rebuild.
The excessive blow by is a sign of worn cylinders and rings. The blow by is contaminating and lowering the octane of the incoming fuel in the combustion chambers and is causing detonation.
The Following User Says Thank You to MouseFink For This Useful Post:
cerial (11-05-2018)
