Body bushings on a '57 Chevy truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2019, 05:51 AM
A few years ago, I had read somewhere (here?) that adding rubber bushings between body and frame of a '55-'59 Chevy truck really helps comfort and road noise, NVH, the OEM calls it! Someone was even saying that pieces of rubber cut from a tire worked well!
I have a '57 Chevy Suburban, and I am still thinking it could be a good idea, so I have a couple of questions:
Is it really worth it? Does it really help with vibrations, noises...? (I cannot see how it would not help, but...).
Using old tire bits seems a bit rustic, I would rather do it well and use real rubber bushings, anyone knows what size I would need (diameter, height) by any chance; I prefer to have the parts handy before I take my truck apart... I bet I would need new bolts, too.
Is it a horribly difficult job? Anyone has advice, ideas... that would help? I am not taking the body off the frame for a restoration, just lifting it enough to add bushings.
Thanks!
Old 11-03-2019, 05:57 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
On something that old, expect to replace all the bolts and have a heck of a time with them. Also, it being a full body Suburban, it will be a lot more mounts than a pickup cab.
Not sure if anything is made for that, but you could cut some pieces out of old industrial belting, like from a gravel pit if you can get a hold of some.
I wonder if common sense will ever make a comeback?
Old 11-04-2019, 01:16 PM
ogre's Avatar
the 'Duracell Project'
suburban/panel body mounts are just high durometer rubber square washers 1/4" thick
yours are probably original, first check your mounts and all the bolts
these trucks are very noisy by the method of construction
sound deadener is very limited in the amount of noise transmitted into the cab
look at these from brothers and see if you can find something similar over there
you really need to post a pic of your panel too
The Following User Says Thank You to ogre For This Useful Post:
wave1957 (11-06-2019)
Old 11-06-2019, 03:11 AM
Since Ogre asked...
Old 11-06-2019, 08:19 PM
ogre's Avatar
grrr... sexy
wave1957 (11-08-2019)
