Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Body Work Questions
Old 01-06-2018, 07:34 AM
tech69 tech69 is offline
put up or shut up
I guess if you insist on doing them with filler use a straight edge on areas of concern. It will tell you a lot, even though the entire line might not be straight itself and naturally bowed. It will still be very useful. Rattle can primer when it's freshly sprayed will also tell you what it will look like in paint. Just be sure to sand it off afterwards.
