Brake booster leaking vacuum - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2019, 04:53 PM
Dclifton32's Avatar
My new dual brake booster is leaking. I found this after my SBC would no Idle down. I don't have a boot on the booster, do you think it would help.
Thanks
Dclifton32
Old 02-11-2019, 05:33 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
How did you find the leak, unplug the booster and cap the line?
Boot is a dust cover, check the check valve, that black thing the vac hose connect to. Also make sure the check valve is seating good in the grommet .
Old 02-11-2019, 08:11 PM
Dclifton32's Avatar
I can put my finger over the check valve and engine runs smooth. I took the booster off and put a vacuum pump on the booster and I couldn't get more than 15 in vacuum. This pump pulls 30" of vacuum easily. I also put a bag on the petal side of the pump and applied the vacuum again and it sucked the air out of the bag.
Thanks
dclifton32
Old 02-12-2019, 04:43 AM
Bob37pont's Avatar
Curmudgeon at Large
The diaphragm in the booster is bad. New booster should be under warranty, exchange it.
Old 02-12-2019, 05:31 AM
Dclifton32's Avatar
I will thanks, I have never seen one do that before.
Thanks again
dclifton32
Old 02-12-2019, 10:39 AM
rip-tide's Avatar
Thanks
dclifton32
Reads like you nailed it .... cool
Old 02-12-2019, 11:25 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Before you trash a brand new booster, did you check the seal between the M/C and the booster? GM factory boosters use a rubber seal at that location. If that seal is missing, you'll have a massive vacuum leak.
Old 02-12-2019, 12:27 PM
Dclifton32's Avatar
I purchased from Speedwaymotors, they said they would take it back.
Thanks everyone for the help
Dclifton32
350 valve covers leaking and leaking and leaking 85cjsm350 Engine 13 04-17-2016 07:35 PM
Brake booster vacuum leak 70 ElCam Suspension - Brakes - Steering 11 10-03-2010 11:30 PM
power brake booster vacuum canister?? Ed ke6bnl Suspension - Brakes - Steering 1 10-21-2004 04:33 PM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
vacuum brake booster 48Man Suspension - Brakes - Steering 1 01-14-2003 06:10 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
