brake booster rod travel - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2019, 03:07 PM
Have a booster from Speedway, need to remote mount it. The question being "how long is the input shaft stroke from full out to fully in" ? I need to make a drop in the connector shaft from the floor mounted pedal to the booster to clear the trans mount and attach the end to the threaded booster shaft. I am concerned with how much of the shaft end I can use without interference. Is my question even understandable? I can't push the shaft in by hand as it isn't hooked up and, I assume, I need vacuum.
Old 02-03-2019, 07:19 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Not by me.
Old 02-03-2019, 10:31 PM
39 master's Avatar
booster
You can move the booster back to in front of the rear wheel with a rod running from the pedal to the booster. You did that already. Two things, first the pedal ratio and travel will answer your question about how far the rod should travel. To say it another way, an aftermarket pedal with a ratio of, say 6:1 that normally was hooked almost directly to the booster (pedal, booster, M/C set)will have the same travel when the booster is relocated further back, just a longer rod. Second is the rod itself. You must have a stout rod to prevent ANY flex. Hope this helps. Oh, and even if you have to put a bend in the rod it still will have the same travel.
Old 02-04-2019, 07:02 AM
O K...the booster has a threaded rod, with a nut,extending from the booster. How much does that rod move into the booster? ! inch ? Two inches? Inch and a quarter? If I know how far into the booster...I will know how much of that rod I can use to attach my brake pedal connector rod. The booster has never been on a car and I don't even know how they are NORMALLY hooked-up. With the booster on the bench, I cannot push the rod into the booster by hand to measure the travel.I assume because there ain't no vacuum yet.Is my reply as muddled as the question?
Old 02-04-2019, 07:33 AM
39 master's Avatar
Booster
The threaded rod is used to adjust the pedal free play. As a starting point use about half the threads and see where the the pedal free play stops. The free play should be about 1" or so before you start to feel resistance as the rod starts to push the diaphragm. As a side note don't push the brake pedal on a new, dry master cylinder. There would be a good chance the front piston will stick down.
Old 02-04-2019, 07:51 AM
S10xGN's Avatar
Gotta love a turbo!
Most of the master cylinders I've seen had between 1" and 1 1/8" of piston stroke. I guess that's what you're asking?
Russ
Old 02-04-2019, 08:21 AM
YES! Thank you S10xGN ! Now I know what I can work with. Thank you!
Old 02-04-2019, 08:23 AM
39 master's Avatar
Booster
Nope, not asking anything, trying to tell you about rod travel. The 1" and 1 1/8" thing is the M/C bore size and has nothing to do with rod travel. You need to do research on M/C, boosters and brakes in general.
Old 02-04-2019, 08:24 AM
Ooops, my bad! S10xGN...it didn't register that you referenced a master cyl, and not the booster. Sigh!
Old 02-04-2019, 11:18 AM
bsa_bob2's Avatar
Originally Posted by techinspector1 View Post
Not by me.
Me either! Explain it again ...but ............real slow.Works for me
Old 02-04-2019, 04:10 PM
If the master cylinder moves 1 1/8", the booster also moves 1 1/8". It is linear.
Old 02-05-2019, 02:22 AM
Thought this picture from a Hotrod shop over here might help to show how to mount a remote booster. As you can see the pedal does not have to be in direct alignment with the booster due to the spherical bearing rod end on the pedal rod. You would need the same type of rod end at the pedal arm. You could take the master cylinder off of the booster, put a little bit of brake fluid in it to lubricate it then push the piston in to find out the amount of travel.
Old 02-05-2019, 06:49 AM
So it's linear...Thank you! My question answered.
Old 02-05-2019, 07:50 AM
S10xGN's Avatar
Gotta love a turbo!
Ahh, no. That's the travel of the stroke going from full out to full in. Look again, my post plainly states stroke. Check any automotive M/C you find, the stroke is all about the same...
Russ
Excessive Brake Pedal Travel Russgolfs Suspension - Brakes - Steering 7 09-01-2011 06:56 PM
Tie rod/draglink clearance and front suspension travel question Slomotion34 Suspension - Brakes - Steering 6 04-07-2010 07:34 AM
Excessive brake pedal travel......... Trans Am Tony Suspension - Brakes - Steering 10 05-13-2007 07:07 PM
Brake Pedal Travel yooper Suspension - Brakes - Steering 3 04-23-2004 01:34 PM
Manual brake pedal travel jpd37 Suspension - Brakes - Steering 8 05-22-2003 12:17 AM
