Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Caliper Upgrade Question
Old 10-10-2019, 03:42 PM
Argess Argess is online now
Originally Posted by Tim C View Post
What size master cylinder are you running. To get more pressure between pad and rotor you need a smaller master cylinder or bigger caliper/wheel cylinder.
7/8" for front brakes. Going smaller ought to increase pedal stroke a bit, which is fine where it is now. So am looking at a bigger bore caliper. Am just wondering of a 6% improvement will help me get from acceptable brakes to locking the tires. I have doubts, but I admit, it's a 50:50 thing.
Mind you.... to try it is expensive (only if it doesn't work) at about $500 Cdn for a new set of Wilwoods.
