Brake peddle very low after bleeding - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2015, 04:03 PM
lilrobo's Avatar
i am running hydro boost with a mustang 2 rack i have disc all around , now i plug off my master to check it and it is good ( both ports plugged and full pedal , no bleed off ) now when i pump the brakes i get half pedal ( motor off ) as soon as i start the motor no pedal , i have bleed the master ( 2 ports on side master ) several times , and bleed the wheels several times ,, what am i missing here??
please help
Old 07-07-2015, 04:39 PM
lilrobo's Avatar
ohh i am running a GM pump its on a 5.3 didnt know if that mattered
Old 07-07-2015, 04:51 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Still have air in brakes. Try a slow gravity bleed.
Fact is stranger than Fiction
Old 07-09-2015, 03:48 AM
lilrobo's Avatar
we have bleed like crazy , we bought a new master,, see what happens , we are going to bench bleed it and go from there ,, the old master might have been sitting for a long time
thanks
Old 07-09-2015, 04:49 AM
Last journal entry: 50 Ply wagon
I see this all the time. Disc brakes use a larger volume of fluid and running 4 wheel discs even more so. What many out there don't use are residual valves. They are used inline as close the the MC as possible. When you press on the brake pedal, the pedal is there but spongy. If you press it again it gets alittle harder. That's without residual valves!!
Residual valves are a one way valve. They prevent brake fluid from draining back in the lines. So the pedal stays where its supposed and not get soft or spongy.
I'm not telling you you have to use these to have brakes, just if you want a better pedal.
Residual valves come in 2 types..........10 lb...which is for disc/drum.........and 2 lb which is for disc/disc...............you will need two 2 lb inline.
I have 4 wheel Wilwood power disc on my car with these valves and have a very good pedal.
Mild RV Cam; low vacuum; low brake pedal knightline Engine 2 08-25-2012 09:57 AM
Brake Bleeding. gowser Suspension - Brakes - Steering 2 06-04-2012 09:42 AM
brake peddle johnccarlson Suspension - Brakes - Steering 1 04-06-2010 05:14 PM
master cylender brake peddle very soft bel52air Hotrodding Basics 4 12-30-2007 07:52 PM
brake bleeding mitmaks Suspension - Brakes - Steering 1 10-27-2005 12:08 AM
