brake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2015, 06:09 PM
brake question
will a small 3/16 brake line going back to the rear drum cause problems like mushy or no brakes?
Old 10-26-2015, 04:06 AM
Old(s) Fart
Last wiki edit: Wheelbase database
No, it won't.
Old 10-26-2015, 05:41 AM
I thought maybe I wasn't getting enough pressure to the back I thought the rear drums need more pressure like 10. At least I don't have to change the line
Old 10-26-2015, 08:41 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
Questions:
Is this a custom install?
Disc/Drum?
Do you have a residual valve on the drums? Should have one if you don't. The residual valve holds some pressure to the discs so they don't feel mushy or soft from to long of a pedal stroke to get them to move.
Mark
Old 10-26-2015, 01:05 PM
I installed a p valve that installed but that didn't work. So more valves. Just on the rear or front too?
Old 10-27-2015, 03:14 PM
Stupid question
Do I need 2 for the drum brakes
And where do I install these. They are going on a 3/16 line is that ok
Old 10-28-2015, 03:39 AM
astroracer's Avatar
You should have a 10lb residual on the rears AND the front IF the fronts are drum. If they are discs a 2 or 3 lb. valve is plenty. Go to Speedways site and check out their brake hardware.
Brake Selection and Design
They have diagrams to help point you in the right direction.
Mark
The Following User Says Thank You to astroracer For This Useful Post:
64nailhead (11-01-2015)
Old 10-28-2015, 05:31 AM
That was very helpful But I ordered two 10 lbs for the rear. Oops. From summit dang. I'll just send one back. Thanks for the info
Old 10-28-2015, 05:33 AM
Here's another one there's a wire in my p valve where's that go ?
Old 10-28-2015, 08:37 AM
S10xGN's Avatar
Gotta love a turbo!
It goes to one side of a dash indicator bulb, the other side of the bulb is hot with key-on. If/when you have a brake failure, the prop valve will ground that switch, completing the circuit, and light the bulb...
Russ
Old 10-28-2015, 09:29 AM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
Mushy brakes is air in the system. Air compresses, fluid doesn't. Residual valves will help to keep the pedal travel to a minimum as they don't allow the cylinders/calipers to fully relax so in effect the brakes are lightly applied all the time.
Chet
steering question and brake booster question Hwyhogg Suspension - Brakes - Steering 0 11-21-2010 05:02 PM
brake question oldrodder43 Suspension - Brakes - Steering 2 09-25-2007 11:45 AM
brake question marlene kit car Suspension - Brakes - Steering 8 09-24-2006 12:20 AM
brake question Tissue Suspension - Brakes - Steering 5 03-22-2004 05:28 PM
Brake Question horvath Suspension - Brakes - Steering 8 08-09-2003 08:49 AM
