brakes binding up sometimes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2019, 07:22 AM
delawarebill's Avatar
a friends '34 chebby with p/b and drums on rear. it has a proportioning valve. this spring we did a full brake rebuild with rear wheel cyl, spring kit, and shoes. drums were fine. this past wkend he said the rears locked up. this is the second time. it seems it happened both time on a longer drive. let it sit to cool and turn off proportion valve and drive it.. front disc only then. i've ever used one so my question is there something inside it that keeps all the fluid returning to m/c or at least zero presser ?
could this be a sign of a bad valve also.. it looks like a regular valve that would restrict flow...
Old 08-05-2019, 08:05 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
How old it the rubber flex hose ?
Pep
The Following User Says Thank You to rip-tide For This Useful Post:
Rip VW (08-07-2019)
Old 08-05-2019, 08:41 PM
chasracer's Avatar
True Hotrodder
Is this an OEM type proportioning valve? If it is, they can cause a brake lock up on you. While I don't fully understand it, there's a roller ball or something similar inside these units that is supposed to reduce the amount of line pressure going to the rear drum brakes. When the valve starts to fail, the amount of line pressure increases, which causes the rear wheels to lock up.
It can be a dangerous issue and the valve needs to be replaced.
The Following User Says Thank You to chasracer For This Useful Post:
delawarebill (08-06-2019)
Old 08-06-2019, 11:49 AM
brakes on a st rod
i think the car was build about 5 yrs ago. and of course all was new at that time. the valve is the only thing we didn't replace this spring when doing a full refresh of bks. we replaced the m/c also. now one thing i recall now is we had a hard time bleeding the rear's.. i had to use the manual brake bleed sucker on the bleeder to get to bleed. maybe that should have been the alarm but like i mentioned i've never needed to use a valve in my Tbuckets builds
and did not replace any lines.
Old 08-06-2019, 03:10 PM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
For what it's worth, one day while driving down the road, I smelled something... stopped, walked around the '96 Tahoe, there was smoke coming out of the passenger side front disk brake area.. come to find out, the flex hose to that brake had collapsed (i guess) and it was totally stopped up.. new flex hose and all was well from there on... just a thought...
The Following User Says Thank You to '49 Ford Coupe For This Useful Post:
delawarebill (08-07-2019)
Old 08-07-2019, 07:15 AM
u just reminded me of something
this past spring was the first time this happened.. driving to a show about 80 miles away and was following him... i saw smoke coming from left rear drum. that's when we let sit and turned off valve and no problem after that.. of course he only had front's.. thanks for the post for i totally forget of that one..
Old 08-07-2019, 09:07 AM
question on portioning valve
his valve has 2 lines.. one in one out.. he said he's gonna replace the valve and i suggested also changing the single flex to the rear for kick.. so how does the adjustment work on them valves. like mentioned my or his first in using one..
Old 08-07-2019, 09:53 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
I gotta go with Rip Tide and say probably a bad hose from rear end to frame or body.
