Bubbled powder coat on pot metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2017, 01:18 PM
Last journal entry: Start over
Since the chrome on my headlight rings and trim is shot I decided to do black chrome powder coat. I've done some of the interior pieces that are steel with good results. The trim not so much. I blasted, washed with acetone, and baked at 250*. Coated and cooked according to instructions. I've got a lot of little bubbles and it looks like hell. I tried sanding them down & re coating but the same thing happens. Is there a primer PC that I could use? I had it happen on an intake manifold too put I didn't pre-heat so it's not unexpected.
Old 04-18-2017, 08:52 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I think the pot metal has pores in it and those pores will hold contaminent. I would sand it again to let the solvents out, let it set or prebake it again and repeat. Not sure but worth a try on my world..
Sam
Old 04-18-2017, 04:55 PM
I found a sandable PC primer and ordered it. Baybe this will fill the pits and seal it. I used the hi-temp lab metal on some of the dings and it works good. If it still bubbles there's an out gassing primer that might work.
Old 02-15-2018, 10:53 AM
What was the answer to this situation? I'm looking to have several trim pieces on my henry j powdercoated.
Nathan
Old 02-15-2018, 05:10 PM
No luck so far. I've done it 4X and it gets better but still not perfect. Sometimes instead of bashing the part with a hammer, I'll set aside for awhile. This is one of those times. I might try the outgassing primer but not today.
The Following User Says Thank You to belchfire For This Useful Post:
AutoGear (02-21-2018)
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Pot Metal Welding 84layinframe Body - Exterior 11 07-04-2013 06:46 AM
Painting Pot Metal New Bird Body - Exterior 1 06-05-2011 08:32 AM
Pot Metal?... AmericanPackMule Engine 1 03-26-2009 07:02 AM
Pot metal question Longboard Body - Exterior 12 10-31-2008 02:21 PM
Welding pot metal oldguy829 Body - Exterior 3 09-02-2008 03:56 PM
