Buffing Out Single Stage Paint "From a Production Shop Perspective" - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-28-2005, 07:58 AM
Jim I am using A urethane based single stage paint, non Metalic, Non
enamel. The paint is made by Valspar.
Its supposed to buff out Ok, so I will have to see in a day or so if
this is correct or not.
Thanks. X
  #17 (permalink)
Old 11-28-2005, 12:56 PM
Your original question's been answered in detail, so I won't go into that, but to add my own thoughts on the SS vs Base & Clear issue:
If I'm doing a full paint on an older vehicle, or a commercial , then SS is my first choice (providing it's a non-metallic of course). It is far quicker than B&C, exact colour matching isn't a problem on an overall job, and a 'perfect' finish isn't usually required.
Anything else (late model cars, part paints) and I'll use basecoat and clear, unless the vehicle is already painted in SS, in which case I'll use that for originality.
  #18 (permalink)
Old 12-28-2006, 09:29 PM
help with single stage
Painted a car today with single stage black,didn't use hardener just reducer. Can I still wet sand and buff out orange peel, or just use a rubbing compound. It was dulipcolor from Napa .I've never used it before got a good deal decided to give it a try. thanks in advance for any help.
  #19 (permalink)
Old 12-28-2006, 10:27 PM
colormecrazy's Avatar
Paintshop Dog
Originally Posted by BondoKing
well from a production standpoint, no one is using ss paint first off... it is base clear for the production shop... second when you need to remove peel or dirt you are going to do so by sanding and then buffing... If you dont like sanding you will never like body work or paint work... It is a hundred hours plus of sanding sanding sanding.... We are professional sanders
Yah! What he said!! If you are going to do this kind of work... you gotta get over the "ooooow! I don't want to sand" bologna! You gotta LOVE it!
With that said, Nobody said anything about using a razor blade. Cut the large trash off, carefully. You can save time and avoid excessive sanding in some cases. Just be very careful to lay the blade flat, don't dig in or gouge the paint.
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 06:33 PM
Single stage paint papabird Body - Exterior 4 07-27-2003 09:01 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 01:56 PM
looking for a shop that shoots lacquer paint domenicsantucci Body - Exterior 3 01-08-2003 02:51 PM
San Francisco Area Paint Shop billcar670 Body - Exterior 3 10-24-2002 05:33 PM
