Buick 401 Value? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2008, 02:34 AM
Buick 401 Value?
Hey everyone,
They just got a 65 Buick Wildcat at the local U pull it. Engine is complete minus the carb, pulled the valve covers and looks really clean. Any idea as the the value? Looks like a really cool engine and might be worth getting for a project down the road Any ballpark figure as to the value?
Thanks
Jordon
Old 09-12-2008, 07:16 AM
ChevelleSS_LS6's Avatar
Instagram: partsretriever
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
get the whole car! bufords rock, especially the wildcats (think rich man's GTO.. might be different frame GM built them on though..., much as an Acura Integra is a rich man's Civic. But no matter which way you look at it, the Integra and Civic drive the wrong set of wheels, are missing four cylinders, and sound like ******* with a performance exhaust on them.)
Old 09-12-2008, 01:37 PM
BMM BMM is offline
If im not mistaken, a 65 COULD have had a 425 Nailhead...465 lb/ft torque from the factory!
Old 09-12-2008, 01:41 PM
Wiki Edits: 31
I think the Wildcat only came with the 425, but I'm not sure
Old 09-12-2008, 04:23 PM
Wildcats and Rivs had the 425. Pick up the Nov Street Rodder for a Buick Nailhead article including identifying the 401 from a 425.
Old 09-13-2008, 05:16 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
moving this to Hotrodding Basics
Old 09-13-2008, 04:18 PM
Base engine in the wildcat was the 401. in 66 if the engine was a 425 then it came with a Q-jet carb and intake. in 65 the only induction available was the carter AFB. a good 401 core is worth 300.00. keep in mind that the wildcat has a center sump oil pan and the rear sump pans which would be required for most hotrod projects are only found in 65-66 Skylark GS cars and 59-60 cars. the rear sump pans are tough to come buy and a bit pricey.
Old 09-15-2008, 04:17 PM
I think it might make a cool engine for a rod.....gobs of torque. Even though it's a center sump, if you didn't have the ability to find a rear sump, I'll bet you could make a baffle to weld into the pan behind the pickup, to keep the oil where it belongs.
Old 09-20-2008, 11:23 PM
the sump location causes problems when installing a car with a crossmember that runs right under the motor. if the car has a front crossmember then it's not an issue
Old 10-23-2008, 03:13 PM
Thanks for the help. Well I went back today and someone all ready pulled it. Actually im glad to see someone got it rather than going to the crusher!
Jordon
Buick 401 Nailhead questions BMM Engine 3 04-11-2008 10:34 PM
Buick 401 Nailhead - questions heyjude076 Engine 13 03-21-2008 11:18 PM
Buick 401 And T400 jpage Transmission - Rearend 8 02-18-2006 11:21 PM
Ideas for a Buick 401 Nailhead ckucia Engine 5 05-20-2005 09:51 AM
ST400 to TH400 on a 401 buick JUSTINH Transmission - Rearend 3 11-04-2002 11:07 AM
