Buy T bucket with or without floor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2017, 06:10 PM
Wiki Edits: 31
I'm waiting on getting the very last of the funds together to get my T bucket kit shipped. Spirit offered me a body that had a slight blemish and no floor for $325 which is about 1/2 of the cost of a body with a floor installed. I took that body since I'm on a budget.. I know that I can call them and have them stick a floor in it for a cost, but their floors are 'glass with a Nida core or similar reinforcement. I know the tried and true is a plywood encapsulation. My only concern is fitting the body where it needs to go on the frame, since Spirit pre drills the holes for their body mount tabs when you buy a floor..
Should I have them put a floor in?
Old 12-23-2017, 07:46 PM
39 master's Avatar
Floor
My vote is for you to do it yourself. Set it on the frame where you want it, do some glassing and then you can say " I built this". You may want to change the attitude from "factory" anyway.
Old 12-23-2017, 11:32 PM
T bucket
Well, to begin you have to ask two questions? How is your experience at fiberglass work and how are your wood working skills. I would always buy a T bucket body with floor installed. It is so much easier to spend the extra cash and get a body with the floor. About 15 years ago, I researched this and purchased a CCR body with floor. Glad I did. It was so strong and took minimal sanding to prep for paint. It was about three times the cost of a cheaper body but it was well worth it in the long run. I was impressed how heavy and strong the body was. Made the finished project soooo much nicer.
Old 12-24-2017, 06:06 AM
BillPac's Avatar
It depends . . .
Since you already have the body without floor, do it yourself. I also bought a floorless Spirit body, and since I wanted to channel it about 5", I set it on the frame rails at the appropriate height, then made a cardboard template as a pattern for my 5/8" plywood. Came out nice, I think.
Old 12-24-2017, 06:36 AM
Wiki Edits: 31
Yup, looks like it came out very nice. One question, does the Spirit body just 'drop on' at 3" channel? I have not figured out if there is anything to do at the rear, but I know the front is cut for 3"
I have a lot of fiberglass supplies left from a boat restore. Lots of CSM and that other stuff that is CSM and cloth stitched together. cannot think of the name. I planned on putting a layer of CSM into the back wall at the very least, probably the cloth combo stuff simply because I have it.
Otherwise, I pretty much want to build this out as much 'kit' as possible. Simply because this is the first one and doing that eliminates fabrication issues. I won't be running their seat insert since the finished interior is spartan and still looks like a butt cheek. I like how the steering column is supposed to attach right to the Vega box without linkage
Old 12-24-2017, 07:11 AM
delawarebill's Avatar
bucket floors
i also did my own when i built it. not a big deal. use 3/4 plywood and just lay on frame. now put body on the ply and draw it out to cut. u will want to drop it on from the inside so it'll sit against the glass body. drill your own holes in frame or weld on "L" brackets to frame and threw bolt it. i also used two 1/2" plywoods glued together and glued to back side of fire wall. that gives u enough thickness to attach fuse panel and other stuff. don't put the fuse panel under seat.. keep thinking rain.. i also used the 10 gal gas tk and slide to drivers side to allow room for battery. tight but worked well. i used the 8" rear from a '67 mustang and perfect fit and ran 20" wide tires. are u going to do your own wiring too?? they may be making smaller fuse panels now but in past the smallest was like 10 or 12 fuses... way to many, and the wiring harness was tooooo pricey for what a bucket uses. i did my own too.
Old 12-24-2017, 07:29 AM
BillPac's Avatar
Channel . . .
I had to cut additional 'relief' areas to allow the body to drop down more front and rear, but that's just because I wanted a really low stance. The down side of that is there is less room in the interior, but it suits me. I used sportsman fiberglass bucket seats mounted on the floor.
Old 12-24-2017, 09:27 AM
Wiki Edits: 31
The Spirit frame comes with body mounts attached. Basically L brackets so all I have to do is correctly locate the body and drill holes up through the floor
For wiring I'll probably get something like this. Cheap and simple 8 circuit. https://www.ebay.com/itm/NEW-8-CIRCU...4383.l4275.c10
Old 12-24-2017, 09:33 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
installing a floor
it was easy to get the body where I wanted it then make cardboard pattern, cut the wood with out the body easier to move it. 2 glass body buckets and then the real steel body I found in 1951, still in the barn and needs some upgrades, my son said he will do with a grandson
Name:	t bucket.jpg
Old 12-24-2017, 01:47 PM
NEW INTERIORS's Avatar
life is a temporary assignment
I would buy it without if you know how to do glass work.. On my thread on getting rid of the ugly here on hotrodders I show how I re glassed a new floor because it was very bad.. Here's a few pictures.. Plus you can Channel it over the frame if you want too..maybe this can give you some idea's..
ID:	395330   Click image for larger version
ID:	395338   Click image for larger version
ID:	395346   Click image for larger version
ID:	395354   Click image for larger version
ID:	395370   Click image for larger version
ID:	395378   Click image for larger version
ID:	395386   Click image for larger version
ID:	395394   Click image for larger version
Old 12-24-2017, 01:48 PM
just remember the more you channel it the higher up you sit in the bucket..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
delawarebill (12-25-2017)
Old 12-24-2017, 02:03 PM
Wiki Edits: 31
Spirit bodies are notched for a 3" channel. I don't want to go more than that. I prefer to ride 'in' cars, not 'on' them..
Looks like I'll keep it without floor and just run some plywood/ glass.
Old 12-24-2017, 09:13 PM
BillPac's Avatar
Me, too . . . !
ID:	395474   Click image for larger version
Old 12-25-2017, 08:15 AM
bucket build
with seating. don't recall exactly the measurements... but i had the front maybe 6" tall and contoured down to like 2" in the rear. gave a bucket seat feel and had some room under for a few tools and reg/insurance. with brakes i put the m/c under the seat attached to frame. it's hidden and easy to get to for filling. just need to lengthen push rod. another thing i did was add blinker lites. not used with brake lites but separate. way easier to wire up. too bad u don't like closer, talked to my brother last nite and he's going to scrap a wrecked '67 falcon.. that 8" rear would be perfect fit.
Old 12-25-2017, 08:34 AM
Wiki Edits: 31
That kinda sucks, I used to have a '67 Falcon and have on- off looked for another '66-'69. As for the rear, Spirit is providing a GM 10 bolt from an S10 that is set up to the frame. It's not great but it'll work. They also put the M/C in the seat area
As for seat, I'm thinking the Corbeau 42" Baja seat is almost perfect. Just have to have it re covered in something nicer. https://corbeau.com/42-baja-bench.html
floor/firewall mounted or under floor/frame pedals? 31ROC Hotrodding Basics 10 11-21-2012 05:24 PM
New Unused Bucket Seat Complete Set 2 Bucket & Middle Seat Console seatsman Interior 1 11-01-2011 12:27 PM
Where to buy a T bucket kit car 42FORD Body - Exterior 11 05-16-2007 11:38 PM
Where to buy new bucket seats 406chevelle Interior 6 02-18-2007 10:44 AM
