Cam Degree - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2007, 12:07 PM
Cam Degree
Ok, When You Degree A Cam What Exactly Are You Doing?? And How Would You Make It That The Power Comes In At A Higher Rpm???
Old 05-03-2007, 12:44 PM
Big Mouse's Avatar
Stroked Z28
I look at degreeing a cam as a process that makes sure the cam grind is what you expected and making sure of your top dead center. Really, you shouldn't have to mess with much.
Start reading on page 3 of this link (check out the box at the top of that page): http://www.compcams.com/Technical/In.../Files/145.pdf
The BEST way to get higher RPM performance is to choose the right cam based on your gears/tires/trans and how you want the car to perform.
Old 05-03-2007, 12:59 PM
Banned
The most influential part of degreeing the cam is moving the intake closing point. You also shift the rest of the points, like the EVO, EVC, and IVO but they don't have as noticeable of an effect. If you dealy the IVC point (ie retarding the cam) you can shift your power band up SLIGHTLY. A few hundered RPMS is the maximum amount that will be seen in the shift. More often than not its done to crutch an initially poor choice of cam, though it can be used for other reasons, especially in racing. Sometimes people also "advance" the cam to help lower the RPM where maximum torque is made in an effort to maek a race type cam more streetable.
Old 05-03-2007, 03:07 PM
Bench racer
Didn't like the answers you got to this question in your last post yesterday?
https://www.hotrodders.com/forum/383-engine-115183.html
What people have been trying to tell you is:
1. This isn't going to "fix" the wrong cam for your engine.
2. Wait until you've actually started the engine before you "decide" it needs changing.
Keep asking till you get the answer you wanted.....
Old 05-03-2007, 03:09 PM
what do you mean what i want???
will this cam work well? STLrocker Engine 9 03-29-2009 09:39 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 09:22 PM
How To Degree A Cam Shaft ? ? ? SCHOONER Engine 1 11-27-2006 07:37 PM
Cam Degree Question rcm800 Engine 2 07-30-2006 07:55 PM
Degree that cam kseay Engine 10 05-02-2005 07:26 PM
