cam and intake advice (drag) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2013, 02:20 AM
Hello everyone, I have a 72 Pontiac Ventura II 406 sbc .200 dome speed pro pistons,steel crank, 6.0 rods, solid roller lifters, dart iron eagle heads 230 runners 2.08 1.60 64cc. 1.5 rockers Holley 830 racing carb. 4.10 gears full spool 8.5 10 bolt 350 turbo 5500 stall. I thank that's all guys need. I need to know what solid roller cam to go with and intake ( victor Jr ) (super victor) or another. im running 1/8 mile and my tires are 26x10wide Thanks for the help.
Old 08-01-2013, 06:34 AM
vinniekq2's Avatar
with out knowing more about the engine and car and head flow?
111163-08 NA 287 293 255 261 .600 .620 108 104 .022 .022
3800-7800 Good mid-range power, rough idle. Needs 11.0:1 CR-up. Brackets.
something like this is a place to start.The heads,unless ported are the weak link si probably a Victor jr.
the 4.10 gears are like highway gears for 1/8th mile
Old 08-01-2013, 04:14 PM
well the head flow. Intake is 307cfm @.700 lift and exh 213cfm @.700 lift. I figured if i went to 4.56 or 5.30 i would be gear dead not having a stroker motor but im new to drag racing so i dont know to much.
Old 08-01-2013, 07:29 PM
vinniekq2's Avatar
1/8 mile
Like I stated before,the heads flowing 307 CFM is a weak point for big power.If you are building a mild-moderate street car,those heads will work.maybe think about how fast you want to go,and how many horses it will take to get there?If the castings can be ported,that is also an option
Old 08-02-2013, 11:31 PM
the 230 thirty heads will flow a ton of air and fuel, just like vinny said good mid to upper range,
however my opinion is where do you want your engine to perform?
.200 dome pistons at 64cc heads depending on head gasket thickness your going to have high compression, and you throw a big cam into the mix its going to mean low vacuum situations which will require higher rpms to develop the vacuum needed to pull proper air and fuel.
so I would look at what your springs are rated for at maximum lift, go .100 under that for coil bind.
406, drag race, engine, hot rod, race engine
350/290 GMPP Engine Build need advice(cam, intake etc) Chevyboy_0 Engine 4 08-26-2010 11:32 AM
Anybody with drag racing advice? Blazin72 Hotrodders' Lounge 28 08-15-2009 03:56 PM
Need some advice on drag truck set-up... Deep Sleep Hotrodding Basics 0 09-03-2006 12:30 AM
looking for advice 79 camaro drag setup jsteve068 Suspension - Brakes - Steering 1 11-19-2005 10:55 PM
First Drag Race Advice bjam2 Engine 17 10-12-2002 04:57 PM
