Camaro hood too high at rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2016, 03:53 AM
Hey guys. I have a '68 Camaro which when I close the hood the rear of it sits too high. Have tried dropping it in the hinge bolt holes and messing with geometry but can't seem to sort it out. Are there any pointers for sorting this out? Is there something wrong with my hinges perhaps? It's quite a lot, like 8mm or 5/16" or so
Old 09-26-2016, 04:02 AM
I think it's sitting up on the rubber strip in front of cowl (but can't delete thread now)
Old 09-26-2016, 04:20 AM
Have removed the rubber. Still no good. The closest adjustment I can get is with the front half of (lower) hinge pushed downward in slot and rear half lifted upward. ends up about 3mm too high
Old 09-26-2016, 04:25 AM
ProStreetRob's Avatar
RedLine Stage 4 ZL1 650rwhp
Pretty common problem on the old classics and one that has driven me crazy for years. I go to a lot of car shows, (it's My Thing) and I'm always blown away but the High Dollar Restored Classics I see with the hood arched in the middle, sticking up in the back, or not meeting the fenders in the front.
I can't tell you how much time I've put into many of my former classics shimming fenders, adjusting hoods, adjusting hinges, and I still have to push the back of the hood down manually every time I close it. Unfortunately Billet Replacement Hinges could be $700.00 so I guess thats why you see so many un-aligned hoods. In Most cases it's just worn out; play in the rivets, springs don't bounce back, or the hood is arched.
Old 09-26-2016, 06:00 AM
This is one of the best how too's on hood adjustment I have read. MartinSR is the origional writer. I think it will solve your problem.
https://www.hotrodders.com/forum/basi...ct-219960.html
John
The Following User Says Thank You to John long For This Useful Post:
22george (09-26-2016)
Old 09-26-2016, 06:28 AM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
I don't know why but many people hesitate or refuse to replace worn out hinges on really nice cars. If it won't adjust and does not have interference, it's the hinges! As I like to say... if it quacks and waddles it's probably a duck. Not all replacement hinges are created equal, some may not even solve the problem if poorly made. Billet hinges are not the only option.
Old 09-26-2016, 06:46 AM
fat tire's Avatar
fat tire
try this link [COLOR=#0066cc]HoodHingeRepair.com[/COLOR] back in the 60s with the big engines they created a lot of heat. especially with uncoated headers. to help eliminate the heat some raised the back of the hood so the engine heat could escape
Old 09-26-2016, 08:19 AM
It's too late to work on it tonight, but Martins article is very helpful. Thanks John. Might help Rob too. It is irritating, my car is very tidy and it sticks out like *********.
Old 09-26-2016, 09:13 AM
John
You know what's funny John, when I opened Hotrodders just now on the body forum I saw "Camaro hood too" that's all I saw and I knew it was "too high at the rear" I knew that is what I was going to see.
Sweetv8, rotate the hinges as explained in the "Basics" and you should have it.
Old 09-26-2016, 09:19 AM
Honestly, the reason you see it so often is the fix is very odd and people don't "get it." I have seen pros doing this stuff for years that don't know you can rotate the hinge or even shim it to get it down. It's so odd, going against your brain that it's missed.
Sure the hinges could be worn too much, or in my case I had mine binding up from the thick powder coating. And even if they are worn a bunch, you go to the limit of the wear, rotate it back.
It's like adjusting doors that are sagging, sure they are sagging because the hinge is worn out. But you can lift it up to where the hinge is holding the door properly. It's still worn, but it can be adjusted to make the door fit properly.
Old 09-26-2016, 11:01 PM
put up or shut up
yeah, rotate it first then start looking at other things. Sometimes if you can push it down with your hands after it's rotated and it only looks nice when you push it down it's the hinges.
Old 09-27-2016, 08:08 AM
That's a great article, thanks for your effort Brian.
The Following User Says Thank You to Sweetv8mate For This Useful Post:
MARTINSR (09-27-2016)
79 camaro hood hinges to 71 camaro swap Gladis Body - Exterior 1 01-10-2008 02:17 PM
camaro = high idle barbiekiller Engine 0 04-14-2006 02:37 PM
hood for 70 camaro 70camaro804 Body - Exterior 4 03-21-2005 07:00 AM
68 camaro ss hood fork Body - Exterior 0 02-11-2004 12:50 PM
High Rise Cowl Hood for '81 to '87 Chevy Truck Venusfly Body - Exterior 6 11-02-2002 02:40 PM
