Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Suspension - Brakes - Steering (https://www.hotrodders.com/forum/suspension-brakes-steering/)
-   -   Can I use the same Motive speed bleeder to bleed a DOT 3 and a DOT 5 system? (https://www.hotrodders.com/forum/can-i-use-same-motive-speed-bleeder-bleed-dot-3-a-522645.html)
ml69 09-01-2019 04:12 PM
Guys,
I have two brake systems I need to bleed, one with DOT 3 and the other with DOT 5. I've already done the DOT 3 one so if I empty and clean it out real well can I use it to bleed the DOT 5 system? Thanks for your assistance.
Mike
LATECH 09-01-2019 05:33 PM
Ehhh, I wouldnt.That is just me.
I would be concerned of contamination, when going from DOT 5 back to DOT 3 afterward.
That silicone based stuff is hard to get rid of. You may contaminate a few systems afterwards, even if you think you have it cleaned out well enough.
When it comes to brakes , better to be safe than sorry
johnsongrass1 09-01-2019 06:23 PM
I’d say it depends on the application mostly.
Stock
Stock stuff I’d live with just cleaning it well.
