Can someone explain how vintage Ford discs work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2019, 05:15 PM
Back in the day, every classic car I had either had drums or four piston disc calipers. Today I pulled my street rod's Mustang II brake calipers and found they have a one piece cast caliper with one large piston, bolted directly to the spindle. There are no typical guide pins that the caliper slides on. Can someone explain
1) how these brakes center and how the outer pad is able to obtain any stopping force on the rotor
2) the procedure to clean and lube the caliper and pads for proper operation
Old 03-10-2019, 12:14 AM
ericnova72's Avatar
More for Less Racer
The brake caliper is supposed to "float" sliding in and out on the wedge shape at each end of the caliper where it meets the caliper bracket on the spindle. One end will have the wedge keeper and a retainer clip in that slide area also.
Dis assemble calipers from the caliper bracket. Clean up with a wire brush and coat wedge areas of both the caliper and the caliper mounting bracket on the spindle with a thin smear of anti-seize paste so the caliper can slide.
Inner pad may need a very sparingly applied bit of anti-seize at the points the pad's steel backer fits to the ends of the caliper and to the wedge area.
Caliper has to slide so that when pressure is applied to the inner side piston it pulls the whole caliper inboard while pushing the piston out, thus pulling the outer pad to the rotor at the same time the inner pad is being pushed by the piston out to the rotor.
GM single piston caliper is the same but it slides on special shaped bolt/pins at either end of the caliper.
A lot of guys always figured Ford's wedge retainer system a real PITA and more prone to freezing up than a pin guided deal. Ford finally saw the light in 1979 or so.
The Following User Says Thank You to ericnova72 For This Useful Post:
36 sedan (03-10-2019)
Old 03-10-2019, 06:44 AM
I agree wholeheartedly that this design is a PITA. Since I'm planning on replacing with 11" brakes eventually , think I'll just proceed with that.
The Following User Says Thank You to mainstreetprod For This Useful Post:
Old 03-10-2019, 07:38 AM
36 sedan's Avatar
[QUOTE=mainstreetprod;4659299Since I'm planning on replacing with 11" brakes eventually , think I'll just proceed with that.[/QUOTE]
That is exactly what I did, my only regret is that I didn't do it sooner!
Old 03-10-2019, 08:19 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Yeah, look again. As noted, the caliper slides in that cast bracket, and the bracket bolts to the spindle. The caliper will come out of the cast bracket once the bracket is off the spindle. If you look closely at the photo you posted, the caliper in back does not have the bracket - only the caliper in front. This is what the bracket looks like when you slide the caliper out of it.
Millions and millions of cars use this same design, including most Hondas and Toyotas. I don't think it has an inherent flaw. It's possible that the sliding mechanism is rusted. The calipers on my 1986 Chevy one ton dually mount essentially the same way, without pins.
Old 03-10-2019, 08:39 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
ford calipers
From my post a couple days ago
The Ford design sliding calipers tend to rust and not slide, wear out one side of the rotor and pad, the Gm pin calipers work better but volumn is not matched. the new Mustang Gt dual piston with the GM design pin mounts work best. Some of the mustang -smaller ford forumns show how to make the Gt adaptor brackets.
There are some disc brake kits that use the granada sliding calipers and the 11 " rotors. I use a fine tooth file and dress the sliding surfaces and give a little more clearance then lube as noted in the other posts.
Ford did the Durability tests on the sliding calipers at the Arizona Proving grounds. If they would have done the test in Dearborn on city streets in the winter with all the salt and slush they probably would have dropped the design.
Old 03-10-2019, 08:45 AM
Old(s) Fart
I'm guessing that there aren't a lot of street rods with MII front ends driving in salty slush. In any case, a dab of anti-seize on the sliding surfaces goes a long way here. I've owned lots of vehicles with calipers that slide on the bracket as opposed to pins, and drive them in mid-Atlantic winters. Never had a problem.
Real body and paint work. 40 Ford novafreek6872 Body - Exterior 40 07-07-2015 09:33 PM
1930 Ford Coupe Sheetmetal Work flop Body - Exterior 33 08-18-2013 06:52 PM
Wwill a 1988 sable/taurus 3.8l electric fan work for a .30 over Ford 302 Theomega76 Engine 10 09-06-2010 12:12 PM
making ford aod work in street rod? garypiatt Transmission - Rearend 3 03-16-2003 10:14 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
