Can you identify this front end for me? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2019, 12:36 PM
I'd like to repair/replace or change to discs but don't know what I'm starting with. It's a 46 Ford with a 302 engine and I'm sorting out what other mods have been made. Photos attached.
Name:	Ford 46 Left Front Suspension.jpg
ID:	440973   Click image for larger version
Name:	Ford 46 Center of Suspension.jpg
ID:	440975   Click image for larger version
Name:	Ford 46 Right Front Suspension.jpg
Old 03-04-2019, 01:49 PM
39 Sedan's Avatar
Could be a mustang 2 rack and pinion but i can not be sure.
The Following User Says Thank You to 39 Sedan For This Useful Post:
46FordJohn (03-04-2019)
Old 03-04-2019, 02:13 PM
Old(s) Fart
Last wiki edit: Wheelbase database
Wow, talk about a blast from the past! That sure looks like a Pacer front end. Note the same bolt-on steering arms. This was a popular front clip to use on rods when Pacers were common. The rack and pinion conversion was also popular.
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 03-04-2019, 03:25 PM
Thanks for that. My brother has a Pacer front end on a 50 Chev panel. I'll see if he can photo it for me.
Old 03-04-2019, 03:26 PM
Thanks for that. My brother has a Pacer front end on a 50 Chev panel frame back in Oregon. I'll see if he can photo it for me.
Old 03-06-2019, 09:10 AM
kso's Avatar
kso kso is offline
Agreed about Pacer, especially with the drum brakes. I don't know of any other car that used them with a rack-and-pinion steering. Track for the Pacer is wide at 61.2 inches and the suspension is a bit heavy but the main thing is, if the width's right for the car then that's the one to use. Discs were an option if you should choose to change to them.
Back in the day I helped a buddy pull one for his drag-oriented '37 Willys build, both of us were new at that but ready to try anything. I don't think it ever got used, would make a better street setup.
The Following User Says Thank You to kso For This Useful Post:
46FordJohn (03-06-2019)
Old 03-11-2019, 08:50 AM
Pacer front end question
Is there a sure fire way to tell for certain if mine is a Pacer front end? My brother is not responding to my request to check out his old frame with a Pacer front end. It could be the snow has slowed him a bit. That has a tendency to do that when you are 84. Thanks - John --
Old 03-13-2019, 08:06 PM
You definitely have AMC spindles. That is a good thing, because by using the correct stub spindle and rotor you can install any AMC disc brake on your spindle. Ambassador, Matador, AMX, Javelin, Hornet, Concord will all fit by changing the spindle stub. AMC only used two different stubs from 1950 to 1986, and they interchange on the spindle.
The Following User Says Thank You to enjenjo For This Useful Post:
46FordJohn (03-14-2019)
Old 03-14-2019, 03:15 PM
AMC Spindle
I'm not certain how you can tell that it is an AMC spindle but I will take your word for it. I measured from outside of brake drum to outside of the other brake drum and it appears to be nearly 61.5 inches. Is there any other conversion that might be that wide?
Thanks again, --John--
Can you identify my front suspension ? 48PontiacTorpedo Hotrodding Basics 9 02-25-2016 07:15 PM
help me identify this front end 71corvette Suspension - Brakes - Steering 19 06-13-2010 11:33 AM
Can you help me identify this engine! Estel Hotrodding Basics 7 06-10-2007 09:01 AM
Can you help me identify this engine! Estel Engine 0 03-31-2007 08:09 PM
Can you help me identify these 32 Ford spindles? LittleTruck Suspension - Brakes - Steering 4 01-11-2006 09:21 AM
