Car barely made it up the hill (transmission issue) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-01-2020, 07:57 PM
Excellenceautosoluti's Avatar
Originally Posted by 47 Ford Coupe Delux View Post
So are you guys saying this doesn't sound like a transmission issue? I mean what else would cause the engine to rev up and not move in drive or reverse?
Sounds like your tranny is DONE.
  #17 (permalink)
Old 08-01-2020, 08:15 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Maybe the transmission is in two gears at once...
No TransBrake I assume?
  #18 (permalink)
Old 08-06-2020, 08:38 PM
47 Ford Coupe Delux's Avatar
Update: So, I drained the transmission fluid and removed the oil pan and what I found at the bottom of the pan looked like The Blob! Also the filter was totally clogged with the stuff. I replaced the filter and tomorrow will add fresh fluid and hope for the best.
  #19 (permalink)
Old 08-07-2020, 04:19 AM
64nailhead's Avatar
If it functions enough to drive and you're not the type to pull and/or rebuild this yourself, then I'd drive to the local transmission shop of choice to have it fixed properly.
If you've only burnt up clutches, then the rebuild won't (shouldn't) be very expensive. Hoping this thing will function with an oil and filter change only is extremely wishful thinking (not to be the bearer of bad news).
  #20 (permalink)
Old 08-07-2020, 09:35 PM
Drained the ATF and replaced the filter and cleaned the oil pan and it's running good as new. Filter was totally clogged with sludge. Now my only problem is major leak from the pan gasket. Sucks having to take drain it again and try to seal it so it stops leaking.
  #21 (permalink)
Old 08-08-2020, 12:58 AM
boneste624's Avatar
Don't waste your time. Pull it out and rebuild it . Sounds like your pump is toast. Should have pulled it out the first time you felt it slip. You cannot fix slipping with any oil additive or by changing the filter. I hate that lucas snake oil, (homer simpson's voice) "suckerrrrrrr". Is it making any weird noises? One thing that can cause slipping is if the filter clogs/caves in on itself, then you will hear the pump sucking up air, that will cause slipping but swapping out the filter will fix that. Cheap filters will do that. Do you have a trans cooler? If you don't you really need it behind that 383. They get reall hot. Put the trans in neutral and rev up your engine. If it revvs up fine your motor is fine and you have a transmission issue. Last year I picked up a third-gen with a shot trans and It had the same symptoms. When trying to reverse, it would move few feet then would bind up and not move and the rpms would not go past a certain point like you describe almost like hitting a rev-limiter. When in drive I could revv it as high as I wanted and would creep forward few inches. Rebuild time.
  #22 (permalink)
Old 08-08-2020, 07:39 AM
S10xGN's Avatar
Gotta love a turbo!
Have you thought about where all that "sludge" came from? Hint: If it's in the pan, it's no longer on the clutches...
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
47 Ford Coupe Delux (08-08-2020)
