Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Engine (https://www.hotrodders.com/forum/engine/)
-   -   Car stumbles badly (https://www.hotrodders.com/forum/car-stumbles-badly-521941.html)
Onepieceatatime7 07-10-2019 01:33 PM
Car stumbles badly
This is a mut, so the problem could be a couple things. It's a SBC 350. I get it tuned, runs strong in driveway, take it to the street and romp on it and it stumbles at about 5k rpm. Stumbles as in it's out of fuel or something and then continues that when I try to get on it again. can drive it back home, idles fine, runs fine.
Is there something in the carb that could have a blockage?
Also have a MSD 6al ignition with mechanical dizzy and holley 650 mechanical carb. The rev limiter is not set up, but could that have something to do with it, or the dizzy have moved a bit?
I've changed the (electric) fuel pump, lines, filter etc. and have one of those cheap pressure regulators from autozone that you can turn the dial from like 1-6 for fuel pressure, which I have set at 5.
thanks in advance.
cerial 07-10-2019 02:00 PM
I don't have anything nice to say about a Mr. Gasket fuel pressure regulatior.
I would start by installing a gauge after that pos regulatior to see what your true reading is and how much variation you are getting.
I can almost guarantee that once warm that regulstior is allowing to much fuel through flooding the car.
BogiesAnnex1 07-10-2019 02:25 PM
Could be a lot of things but before I started spending money I'd recomment tightening up the plug gap to .030 to .035 inch. The next step would be to take the 6AL out of the circiut to see how it runs on a simple HEI.
These are tests that take a little of you time but are otherwise freebies.
Super wide plug gaps aren't necessary nor really desireable especially with high compression and overly rich mixtures.
6AL boxes introduce weird problems at times. The do demand that the heads and intake have seperate grounds, lacking these the high and abrupt energies fed to the plugs can and do mess up the electronics in their search for ground.
Bogie
Onepieceatatime7 07-10-2019 02:33 PM
It's mounted right by the passenger side valve cover on the fire wall, so it probably does get heated. Could flodding cause it to stumble as in, someone turned of the switch?
Onepieceatatime7 07-10-2019 02:37 PM
Bogie
I don't know that I even have the alum heads and intake grounded. It's grounded from the frame to the block. It's a points distributor, and the gaps are about .40 if I recall.
36 sedan 07-10-2019 03:32 PM
What is the spark limiter set at in the 6AL?
JMHO, fuel pressure regulators work better as close to the carb as possible.
BogiesAnnex1 07-10-2019 03:43 PM
6AL is what has my attention points are just a switch in this case. Problem with grounding is these things seek ground through whatever they can find which is sometimes back through the electronis of the 6AL, using an HEI just adds another possibility. Not to say this is the issue but solving for the simple first can save a lot of money, if it isn't the problem you're just out some time not time and money.
The block ground is for the starter and mild electrical fields that are DC in nature, even the heads are pretty safe with this bonding to the block with sealant laden bolts and gaskets. The 6AL in not so kind, it is shocking the plugs with a high energy square wave pulse that is hard to absorb through these unintentional connections. Running the heads and intake together with some number 10 wire to the frame or battery negative post insures the ground side of the plugs doesn't find a sneak circuit back through the electronics. This recommendation is nothing new it usually can be found in MSD's instructions but not always it seems to come and go on reprints.
One has to realize that electrical currents move in voltage differentials not adsolute this side is hot and that side not. The left over currents from firing the plugs will take a positive 12 volt circuit to ground if a negative bonded route is not available. Smoking 6AL's, HEI's or capacitors on points is not all that uncommon.
I'm kind of leaning toward electrical rather than fuel pressure since you're not reporting a backfire with this but just a stumble. If it flames out the intake that puts both options on the table, if it doesn't that's a pretty good indicator but not absolute that the mixture is hanging in there.
My prefered electric pump layout is of course more expensive but for a carb I really like to run a lower pressure TBI rated pump for factory TBI using about 15 psi. Then a bypassing regulator with preferably a tank return but tee'ing in the feed line just ahead of the pump if it's back by the tank is OK, you first want some distance to let the pump bypass fuel to cool before being pumped again. This insures a managed oversupply of fuel in the system for a consistent supply at the carb so at high RPMs it doesn't start to lose fuel pressure as demand over runs supply. For a turbo type pump it insures there is always a fuel flow for cooling the motor, it never encounters a near deadhead situation when idleing as happens with a non-bypass regulator.
As for gauges everybody's quality is sucko, price is no indicator of quality. I have a new Stuart Warner vacuum gauge that reads 24-25 inches at a 750 rpm hot idle vacuum on a 350 with a LT4HOT cam, 1.6 rockers, with 10.3 SCR. My old quick and dirty Harbor Freight vacuum/boost gauge with multiple color LED lighting says 16-17 inches, so does my motorcycle multi-carb adjusting mercury manometer.
I also run a Mr. Gasket fuel pressure gauge at the regulator it is set for about 5.7 to 5.8 psi regulated line pressure on the left side inner fender and also a no name mini gauge in the line at the Edlebrock carb which reads about 5.5 psi.
Bogie
lmsport 07-10-2019 04:02 PM
do you know that the valves springs are correct for your setup?
Points floating out is also possible.
is the pump by the fuel tank?
36 sedan 07-10-2019 04:09 PM
I meant to say REV limiter. 6al has rev limiter that requires setting, i believe default setting is 5k.
Onepieceatatime7 07-10-2019 05:17 PM
Ok but this is going to sound stupid. I just hooked up a new timing light that works with msd and am timing of the # 6 cylinder....yeah I know.
It ran ok before but a bit hot and had the stumble, but and it appears the timing was set after Tdc.
Net net.
Itís set at 8 degrees initial with a 21 degree total timing stop in the dizzy. Hereís the thing. Itís holding 185 temp in a 100 degree weather now and a had hot issues before. At idle. I have 15 psi vacuum and she jumps when you stomp it, but will not test tonight due to bud light.
Is 8 degrees initial and 29 total ok??......cause the motor suuuuure seems to like it.
Iíll double ground as suggested either way.
8 degrees initial??
Any more than that and she wants to buck a little on start.
Itís 350 , .40 over, zero deck
10.5 compression
Roughly .40 gap on plugs
E street alum heads
Roller rockers
Low rise single plane intake ..... I know, I know...
Shorty headers
650 carb
All mechanical carb, dizzy, manual tranny etc.
So, is 29/30 total timing sound ok?
The temp and vacuum at steady 15 or so make me want to leave it.
I just got vacuum gauge and new timing light.
I donít think the msd box rev limiter is an issue as I have no tach yet, but I did set the dials today @ 6200 to be sure
Onepieceatatime7 07-10-2019 05:19 PM
Temp holding at 185 I should say, which is much better
Onepieceatatime7 07-10-2019 05:22 PM
268h comp cam
ericnova72 07-10-2019 05:40 PM
Total timing at 29-30į may leave a little power on the table, it may prefer the total up near 32-34į for maximum power.
That means with your set-up the initial would need to be 10-12, maybe 14į initial. If it fights the starter too much check your ground connections and battery main cable sizes, Typical parts store battery cables are too small to carry the load well.
If that checks out, you may want to investigate installing an ignition interrupt toggle switch, so you can roll the motor over with the starter easer with no ignition firing, then throw the ignition power on. It helps a bunch with slow cranking cars.
36 sedan 07-10-2019 05:44 PM
Why are you connecting your timing light to #6 instead of #1?
ericnova72 07-10-2019 06:02 PM
Doesn't matter, it will time the same on #1 or #6 because they are both at TDC at the same time.
Often racers will use #6 if #1 plug or wire is in a location that is harder to get to or easier to burn wires on. It's just a convenience thing.
