Carb 350 stumble/misfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2017, 06:30 PM
EragonSuperH's Avatar
I invent stupid usernames
My carbureted Chevy 350 stumbles/feels like a random misfire when accelerating and cruising. The catch though is that it only does this once the engine is fully warmed up. My train of thought says that if it's fine when it's cold, and has problems when it's hot, it's getting too much fuel. Any thoughts? Carb is Edelbrock 1405 600 cfm man. choke.
Old 03-21-2017, 07:37 PM
Last journal entry: Continuing BodModOp... Body Modifiation Operator
One inexpensive answer may be to replace your distributor cap, rotor and plug wires. Yes, all three items. Check your initial timing.
Old 03-21-2017, 08:04 PM
rdobbs77's Avatar
Huge Guns N Roses Fan
do you know what fuel pressure you are running and by chance do you have a carb spacer on there,
Old 03-21-2017, 10:00 PM
4.5 psi and no, only the Edelbrock insulator thing
Those are all brand new, along with the engine being freshly rebuilt
Old 03-22-2017, 01:29 AM
runn141's Avatar
kinda sounds like your manual choke cable isnt opening it up all the way.
Old 03-22-2017, 02:05 AM
Try changing the accelerator pump stroke notice there are 3 holes in the pump arm I rebuilt a Carb for a guy and he had the same issue and that cured it,in another case a guy bought a 1405 manual choke he changed the metering rods to the ones used in a 1406 the bog went away and his mileage gained 2 MPG. These are the ones you would want http://www.ebay.com/itm/Edelbrock-14...VYoL4G&vxp=mtr O'Reillys may have them also. Tech information here: http://www.edelbrock.com/automotive/...ers-manual.pdf
Old 03-22-2017, 08:52 AM
RWENUTS's Avatar
Timing!!
What's your timing set up like?
Or the unwanted suggestion...
Maybe a flat cam.
350, chevy, hot, misfire, stumble
demon carb stumble @wot bill6368 Engine 6 09-13-2012 04:52 PM
Carb stumble Hwyhogg Engine 8 12-16-2011 09:22 PM
carb stumble under medium accelation hatrecide Engine 21 10-07-2009 05:11 PM
Demon Carb Off-Idle Stumble - Help leejoy Engine 3 06-25-2007 07:14 AM
Stumble off idle in park, carb or ignition problem Dubz Engine 3 05-18-2004 11:29 PM
