Carb issues I think - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 05-18-2019, 04:41 AM
55 Tony's Avatar
Originally Posted by Goneagain View Post
I may have a timing issue @950 it’s 45 degrees.
OMG, my timing abnormalities are spreading. That's about where mine is and it runs great that way except for a little pinging at about 35-40 mph and light throttle. Is that without vacuum or mechanical advance? Wouldn't 45° be for the next cylinder? 360/8 is 45 or is it half of that?
Young enough to learn ... too old to remember.
  #77 (permalink)
Old 05-18-2019, 05:17 AM
Goneagain's Avatar
I’m not sure what’s going on last time I checked it I had [email protected] rpm with vac can connected. 19 initial. Starts easy not like it’s to advanced. Thinking of putting The distributor back to stock and try It without the crane advance kit. I haven’t even tried to adjust the vacuum can. Eliminate some variables. Haven’t had it on the road yet don’t trust it. Plus it’s raining
  #78 (permalink)
Old 05-18-2019, 08:00 AM
36 sedan's Avatar
Yes, you have a timing problem! Check to be sure your timing marks are accurate.
I believe (as it was suggested before) you are setting your initial timing with the mechanical advance already starting into its curve (advanced). This will give you tuning troubles.
IMHO, I would suggest you map your mechanical advance curve to know where it starts, finishes and how much it adds. Then adjust it accordingly. I would also map the vacuum advance and adjust it too.
The Following User Says Thank You to 36 sedan For This Useful Post:
Goneagain (05-18-2019)
  #79 (permalink)
Old 05-18-2019, 08:05 AM
36 sedan's Avatar
JMHO, Pinging is NOT good, slight, light throttle or not. Pinging is telling you the motor does not like the timing. Continued pinging can lead to motor damage. Fix the timing...
  #80 (permalink)
Old 05-18-2019, 09:19 AM
55 Tony's Avatar
Yes I realize that. I had already retarded it some but still have to go back a little more. You can't hear it unless next to a concrete barrier like when going over a bridge and the sound bounces off it. It's not at all like a detonation knock (which I have heard plenty of), much much fainter, almost like solid lifters but a little higher pitch.
  #81 (permalink)
Old 05-18-2019, 09:33 AM
36 sedan's Avatar
Not trying to offend, disrespect or anything else. Really just trying to help;
JMHO. Pinging is detonation, it may be less than a severe knocking, but never the less in any form it can lead to damage. Look at your plugs, any peppering on the insulator is an indication of metal transfer (not what you want).
Timing and AFR is really important to longevity on the street.
  #82 (permalink)
Old 05-18-2019, 02:35 PM
55 Tony's Avatar
I appreciate your advice. What I meant was there is a difference between pre ignition and detonation and the knocking sound comes at different times in the combustion chamber for each.
I know neither is good for an engine. I drove a company car in the 80's that knocked 50 times louder than this. The boss said to just keep putting the cheap gas in it. It went 80,000 miles before getting traded in. It was getting a bit of a rod knock you could hear when revving the engine out of gear. I realize you mean well, but maybe you don't understand how little my problem is compared to a knock that is going to melt and break things. There is a huge difference. BTW, I'm working on a knock sensor gauge that should work with most any vehicle. Not good enough to control timing, just a warning gauge.
The Following User Says Thank You to 55 Tony For This Useful Post:
36 sedan (05-18-2019)
  #83 (permalink)
Old 05-18-2019, 03:48 PM
36 sedan's Avatar
WAY COOL! Keep us posted please
  #84 (permalink)
Old 05-18-2019, 06:38 PM
36 sedan's Avatar
http://www.rockettbrand.com/download...e-Ignition.pdf
  #85 (permalink)
Old 05-18-2019, 06:54 PM
Goneagain's Avatar
I thought I had the timing down. Obviously not. I’ll check it again in the morning.
  #86 (permalink)
Old 05-18-2019, 07:10 PM
ericnova72's Avatar
More for Less Racer
This sounds to me like you need to richen part throttle, not take timing away...
The Following User Says Thank You to ericnova72 For This Useful Post:
  #87 (permalink)
Old 05-19-2019, 03:27 PM
Goneagain's Avatar
well carefully checking the timing with no vac advance
[email protected]
[email protected]
[email protected]
[email protected]
Then it ran out of gas. From my house its an hour round trip into town.
So 14 degrees mechanical advance with stock springs. for a total of 33degrees. maybe a little short.
At 950 rpm hooked up vac advance to manifold and got [email protected] 1400rpm So that's 31 degrees vacuum advance or do I factor in the mechanical.
I was going to try adjusting the advance limiter cam that came in the Crane kit (instructions are not real clear) but the starter solenoid gave up the ghost. Ill put a solenoid on tomorrow and try to figure out the vacuum advance.
  #88 (permalink)
Old 05-19-2019, 04:30 PM
ericnova72's Avatar
More for Less Racer
I think you just pinpointed the very issue.
19° @ 650 rpm...okay
21° @ 950 rpm...we wouldn't like to see it moving up yet, but just 2° isn't a deal killer
28° @ 1200rpm...that's a big problem!! 7° drops out right at the point you are trying to make everything STABLE.
You say you have to set the idle at 1200+ rpm in neutral to get it to idle in gear, this is the reason why. Just as soon as you drop it in gear and idle rpm goes to 950 rpm or less it drops a whopping 7° of timing.
We need to dive into exactly what distributor you are using, and what weights and springs are being used.
We ned to limit the mechanical advance movement to not start moving at all, or move just a degree or two, below 1200 rpm.
Until you can get rock steady timing below that 1200 rpm point, you'll never be able to get it to idle ingear….no matter what you do to the carb.
it could need different spring combo, different weights, heating and bending of the hook in the weight to tighten it up, epoxy limiting of the inboard side of the advance slot.
Can you post pics of the mechanism up close, cap off, rotor off??
Ignore the vacuum advance right now, we'll deal with that later, and it looks like you are very much going to be a candidate for ported vacuum, only using it for cruise speed mileage gains and not at idle at all.
36 sedan (05-19-2019)
  #89 (permalink)
Old 05-19-2019, 10:41 PM
Goneagain's Avatar
As far as I know it’s stock except for the module
  #90 (permalink)
Old 05-19-2019, 10:44 PM
Goneagain's Avatar
Another angle
Summit Carb issues ntrue505 Engine 6 09-13-2015 04:52 PM
1971 Motorcraft 2100 carb issues Ethanman Engine 8 08-12-2015 11:33 PM
Edelbrock 1406 carb flow issues on rebuilt Olds 350? c-towndave Engine 4 08-02-2015 03:18 AM
Carb bog vs timing issues? Hacksaw Engine 18 12-31-2012 04:07 PM
Carb issues, advice needed DeputyDawg134 Engine 6 12-11-2007 12:42 PM
