changing amount of advance on GM HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2004, 03:28 PM
cool rockin daddy's Avatar
Cool changing amount of advance on GM HEI
Hey guys, does anybody know approximately how much to shorten the slots on the advance mechanism to reduce the amount of mechanical advance on the HEI? Can you use epoxy or something similar to that to actually shorten the slots or does it need to be brazed or welded. Thanks.
Old 09-19-2004, 04:42 PM
Last journal entry: PICTURE TEST
slot
If you make the slot .100 shorter you should get about 10 degrees at the crank. I guess you could use jb weld or something but i always weld mine close.
Keith
Old 09-19-2004, 04:43 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves
Wiki Edits: 2
Why ?
If you want to adjust it pick up a new adjustable vacuum advance unit so you can dial it in correctly not to much $ for it.
Luv the smell of NITRO in the morning.
Old 09-19-2004, 04:56 PM
1BAD80's Avatar
Wiki Edits: 2
I would get the new vac advance first before you do anything else. You can adjust it out.
Old 09-19-2004, 05:05 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
There should be no vacuum advance for a WOT take off, that's all mechanical. Your vacuum signal at WOT is nil. Initial and mechanical advance are only ever responsable for about 36-38 degrees, anything beyond that is vacuum. If you're pinging at 46 degrees you don't need to mess with your mechanical, just take off part of the partial throttle vacuum with the canister like george is talking about.
K
Old 09-19-2004, 09:10 PM
Cool
Jmark hit the nail on the head. Need more initial advance but mechanical advance is too much. Braze, weld, epoxy, or what is best way to permantly shorten the slots in the mechanism?
Old 09-19-2004, 09:14 PM
Wiki Edits: 3
IF you're tuned for max vacuum at idle, or close thereto, then you're fine on initial timing. If Jmark wants more timing on takeoff he can use lighter springs!
K
Old 09-19-2004, 10:42 PM
GoneNova/406's Avatar
why don't you simply adv. the cam 4* if you want more take off.
Old 09-20-2004, 08:36 AM
jegs has an msd curve kit that has 3 sets of springs and 5 bushins for $10.00.they will also have a diagram with it thatshows you how to use the springs as a set or how to mix them up just as they will with the bushings.there are so many combinations at all different rpm's that you should be able to make something work.i got one with the distributor i bought from them so it should come with the curve kit to.this kit is better than mr. gasket and some of the others.
Old 09-20-2004, 10:47 AM
1BAD80's Avatar
Wiki Edits: 2
You must be careful when advancing cams.
CompCams has 4* advance machined into them to allow for ware.
So at straight up its 4* advanced, it depends on the cam manuf.
Old 09-20-2004, 06:22 PM
johnsongrass1's Avatar
Race it, Don't rice it!
it took off great from a stop, but pinged bad as I got further into it.
I think jmark meant after the car got rolling and the vacuum came up from the reduced load. A sure bet it's the vacuum advancing too much. It goes away after you hammer into it again.
Old 09-20-2004, 09:16 PM
Cool
you guys completely over analyzed the question! I want to run more initial advance to get a better mixture burn at lower speeds, better economy, and generally follow the recommendations for my Speed Demon carb. Instead ot telling me the best way to modify my distributor, which is what I asked for, a discussion on advancing the cam ensues! When the thread didn't talk about cams it addressed using springs to change the rate of the advance, not the amount of advance. I am grateful for the replies, they just didn't address the question!!!!
Old 09-21-2004, 05:42 AM
uh.....
I answered the question!!!!!! read my post......
Keith
Old 09-21-2004, 05:16 PM
Cool
My humblest apologies Keith. You did answer it and I thank you for staying on the subject thread.
