Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - changing engine wiring harness, ran into a lil problem
Old 05-31-2005, 02:41 AM
ikeaguirre14 ikeaguirre14 is offline
im changing the whole wiring harness on my 91 dodge dynasty 3.3l v6. went to wrecking yard found a 3.3l v6 engine inside a 92 chrysler 5th ave. checked it out everything looked okay. pulled it took it home started installing it and everything was matching up perfect. then a got to a connector right behind the drivers side head light. the new harness doesnt have that one connection. i then looked on the 60 pin connectors that plug into the computer and the part numbers were one number off.(i should have checked in the first place, live and learn)
my question is this:
im guessing i got the wrong harness or can i somehow make it work for me?
also the pattern, in which the wires enter the harness, is a little different. i did get the wrong one right. it was the only complete wire harness in the whole yard too. guess i should return it.
OR
should i go back and get the two computers from where the new harness came from and swap them with the ones currently in my dodge now?
any help would be appreciated thanx
