Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - changing engine wiring harness, ran into a lil problem
Old 05-31-2005, 06:34 AM
ikeaguirre14 ikeaguirre14 is offline
maybe i didnt explain it correctly, but the new harness from the 5TH AVE is missing one connector that the old DYNASTY harness has. so now there will be an open connector on the left inside front fender of the DYNASTY. sorry if i wasnt clear on that. also about the two 60 pin connectors. the pattern in which the wires enter the connector are different(example: pins 1, 2, 3, and 10, 11, 15, 16, 17 of DYNASTY connector have wires and the 5TH AVE. connector have wires in different pin positions like pins 5, 6, 7, and 12, 13, 14, 19, 20)
should i go and get the computers from the 5TH AVE and use them in the DYNASTY. since the the harness im puting in the DYNAS was connected to the 5th AVE computers.
i sure hope this is making sense. thanx in advance for your knowledge and information
