chevy 283 - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-25-2013, 06:54 AM
Originally Posted by TimoFinn View Post
Joker, my thoughts exactly,
i like 283 it`s a great little engine and if you cam it correctly and get the 416 heads or Corvette 350 TPI aluminum heads and port them like F-bird told you it will be nice engine to drive, just be realistic about how much you expect it to have hp/tq.
yea i honsetly aint expectin much just more thought it be neat to have rthe motor & just wanted to get details on it before decided to use thanks very much for the help
  #47 (permalink)
Old 07-25-2013, 06:55 AM
thanks joker
watched the videos pretty cool
  #48 (permalink)
Old 07-25-2013, 07:07 AM
Originally Posted by vinniekq2 View Post
buy a cheap intake,dont buy a cheap carb,buy a good carb
i dont honestly see why it wouldnt be a good carb they seem to build good stuff it was summit but i agree i know how much trouble a bad carb can be so if you know something about their carbs please lmk thank you very much
  #49 (permalink)
Old 07-25-2013, 07:20 AM
vinniekq2's Avatar
Thats not what I was trying to say.Buy the best carb for your application.
I dont buy parts on sale,I find the part I need or want,then shop around for the best price.Ive used lots of carbs over the years and most of them do the job they are supposed to do.I have favourites based on 1) easy to work on,2)easy to get parts and gaskets,3)the systems dont need constant fiddling,,,,
for me,and probably not for you,,I like to use Holley double pumpers that have removable air bleeds and metering blocks,not metering plates.I dont need a choke for my car as I dont winter drive much.( I have a pick up truck for bad weather)
I dont like the Holley short bowl systems,and I dont like the Holley bimetal choke system.
Other brands are also good,just not something I would buy for high performance...
The Following User Says Thank You to vinniekq2 For This Useful Post:
bry_93 (07-25-2013)
  #50 (permalink)
Old 07-25-2013, 07:25 AM
thanks vin
yea my uncle has a 2bbl holley with the removable stuff ive rebuilt it kinda use to em & my dads race carb is a 4bble like so kinda uswe to adjustin them that would be good to know what u got if u have to do any adjusting thank you
  #51 (permalink)
Old 07-25-2013, 07:41 AM
ok so im sorry if i have seemed like a ********** at anytime im really just part ********** & certain things set it off lol so again sorry & really thanks to all of you for helpin out lots of great info
  #52 (permalink)
Old 07-25-2013, 07:44 AM
their good at pickin stuff up i used the @ & $$ but really than you guys for the help
  #53 (permalink)
Old 07-25-2013, 08:17 AM
jokerZ71's Avatar
Wrench Turner
Northern has some decent 283 engine kits for about $300.You can upgrade your cam & any other parts in their kits.These kits will work for a good stock rebuild.Before you get too far tho,go get that bottomend outta the barn & get it ckd out as much as possible.If ain't worth buildin,no sense in wastin time & energy.If it's good,then take it from there.If not,then it's time for Plan B.
The Following User Says Thank You to jokerZ71 For This Useful Post:
bry_93 (07-25-2013)
  #54 (permalink)
Old 07-25-2013, 08:24 AM
thanks i'll check them out
i'm gonna try to go get it out & check it out depends on how strong i am
  #55 (permalink)
Old 07-25-2013, 08:40 AM
jokerZ71's Avatar
Wrench Turner
Stand it on it's rear end & use a 2 wheeler.1st investment....buy an engine stand !!!
  #56 (permalink)
Old 07-25-2013, 08:58 AM
1971BB427's Avatar
have you tried putting 2.02s on a 283?
Yes, but the work needed to relieve the bores should not be considered for a street or street strip engine. Valve cuts on the top edge of the bore get very close to the top ring on the piston, and also thin the bore walls quite a bit.
If you bore the engine out a 2.02 head will clear, but not with stock bore.
The Following User Says Thank You to 1971BB427 For This Useful Post:
bry_93 (07-25-2013)
  #57 (permalink)
Old 07-25-2013, 09:09 AM
ive got an engine stand it was gettin it out from where it was thanks
  #58 (permalink)
Old 07-25-2013, 09:10 AM
ok thank you bud
  #59 (permalink)
Old 07-25-2013, 09:14 AM
ok i got the motor out was pleasantly suprised the bottom is in great shape no rust at all & it had been rebuilt somebody marked the caps but the bearing where in great shape so the only rust is the top of the cylinders but ran a wire brush over it they dont look bad i'll measre the cylinder & see if they have been bored & heres what it is its a 1967 horsepower was 195
  #60 (permalink)
Old 07-25-2013, 09:31 AM
jokerZ71's Avatar
Wrench Turner
The piston tops should have any overbore stamped in the top.Mite have to clean it off to see it.Be careful with that wirebrush.Not a good thing to use on certain parts.
bry_93 (07-25-2013)
chevy283, s10, v8swap
Chevy 283 MyMalibu Engine 37 07-31-2013 01:24 PM
307 Chevy with 283 Chevy Pistons?? sbc307 Engine 4 10-31-2009 09:26 PM
chevy 283/327 RealGhol Engine 12 05-06-2004 05:46 PM
Chevy 283 d_67_camaro Engine 1 12-03-2002 11:46 AM
Chevy 283 51HenryJ Engine 7 10-06-2002 02:57 PM
