chevy 283 - Page 9 - Hot Rod Forum : Hotrodders Bulletin Board
  #121 (permalink)
Old 07-27-2013, 09:01 PM
so just so u know i cant go buy new heads noway have the money but u all most likely think otherwise but i aint as dumb as i sound just dont know anything about the 283 so throwin it all out lettin u all be my brain off note did see a set of 283 heads today for 75$ really bad lookin though but i am fully capable of workin on a motor & on the heads other than any maching needed i can handle the rest so have alil faith & it'll all be ok but anywho thank yall very very much for your time & all the great info really appreciate it thanks
  #122 (permalink)
Old 07-27-2013, 09:04 PM
oh & joker id say your right cause after that the heads are made different
  #123 (permalink)
Old 07-27-2013, 09:42 PM
jokerZ71's Avatar
Wrench Turner
Well as it stands rite now,all we got is a 283 short block.I'd say til you have the head issue decided,you really can't decide on anything else.Once you nail a head down & we know the chamber volume,then we can pick the piston & cam for the proper CR & even intake.So,I'd say that would be your next course of action.Decide on a head & the rest will fall into place based on that.If you choose to run what you have,your part selection is gonna pretty revolve around that.
The Following User Says Thank You to jokerZ71 For This Useful Post:
bry_93 (07-28-2013)
  #124 (permalink)
Old 07-28-2013, 06:56 AM
thanks bud
  #125 (permalink)
Old 07-28-2013, 06:57 AM
oh & by new i ment new not used
  #126 (permalink)
Old 07-28-2013, 07:07 AM
jokerZ71's Avatar
Wrench Turner
Be really careful w/ used heads.Especially Vortecs.You could easily waste your money on cracked heads.There's no way of know for sure without havin em fluxed.Try to get a set locally.Not EBay or a website.If somebody could get rid of them locally they would,rather than try to sell them there.Also any savings you see on price is gonna quickly be ate up by shipping.IMO,the best way to search used heads is to call around to machine shop trying to find a set.
bry_93 (07-28-2013)
  #127 (permalink)
Old 07-28-2013, 07:12 AM
jokerZ71's Avatar
Wrench Turner
Sounds like you got alotta stuff just laying around.You could prolly trade around somehow,or,if nuthin else with the price of scrap nowadays,take some of the stuff that is unlikely to be used to a scrapyard.Plenty of ways to make a lil money for parts.
bry_93 (07-28-2013)
  #128 (permalink)
Old 07-28-2013, 07:29 AM
yea that was my prob with usin the v6 vortec cause head are the prob with those & this 1 had a gasket blow & wasa drove hot & heads are exspensive for it thats why i went back kto the 283 thanks
  #129 (permalink)
Old 07-28-2013, 08:04 AM
jokerZ71's Avatar
Wrench Turner
You are lookin @ approx $100 apiece to have any of current heads fluxed & properly rebuilt.If you end up needing valves,or,any other parts,or,machine work,that price will go up.You can get a set of rebuilt #601 HO heads @ Allied Motor Parts | Your Cylinder Head and Engine Parts Source for $145 w/ free shipping.They also have good deals on other heads as well.This just an example.You can get a lot better set of heads for $90 after you deduct the cost of having your current heads rebuilt.There are better heads,but,since max HP is not your goal,these heads would work & let you use your current intake.
  #130 (permalink)
Old 07-28-2013, 09:32 AM
hey thanks thats pretty cheap thanks
  #131 (permalink)
Old 07-28-2013, 11:11 AM
hey ive got alot of old trans kits from aapco just any older car like 50's 60's & 70's mainly if yall need anything like that & are in area & want to come i'll give ya a good deal thanks
  #132 (permalink)
Old 07-28-2013, 06:58 PM
sorry
Originally Posted by F-BIRD'88 View Post
If the piston were replaced in this motor, then you will want to measure the piston to deck clearance with the piston @ TDC. Ya this matters. Most people that build a 283 and then are diapointed in the power
never bother with the critical details like the real engine compression ratio.
A small error on a 283 makes a big difference in the rear cr. A small cid engine like the 283 is much more sensitive to a lack of real compression ratio and easy to get it wrong.
Check this before you select or buy cylinder heads for this motor.
So what is the complete casting number and condition of the "462 heads"?
oh i'm sorry completely forgot i'll get them in the morning i aint really checked but they look real clean i'll get the # & check condition for ya sorry thank you very much
  #133 (permalink)
Old 07-28-2013, 07:01 PM
if there was anything else that someone wanted me to get or check just lmk i forget easy thank you oh & i'll get the motor free'ed & cleaned up & check the piston
  #134 (permalink)
Old 07-29-2013, 03:53 AM
jokerZ71's Avatar
Wrench Turner
Once you get the motor cleaned up,you'll want ck to see how far in the hole your current pistons are.Then pay close attention to the pistons you shop for.You wanna get the proper compression hgt & then deck the block & choose a gasket that will give you the best piston to head clearance.As stated earlier'if your head chamber volume is larger than optimum,you may wanna look into a dome type piston rather than flat top to get the best CR.Since it's been rebuilt before,the deck may have already had some removed,so,it's important to ck you piston depth before you tear it down.
  #135 (permalink)
Old 07-29-2013, 06:32 AM
i'll see about gettin it on the stand & i'll clean the top of the cylinders & let it soak & see about breakin it lose
chevy283, s10, v8swap
Chevy 283 MyMalibu Engine 37 07-31-2013 01:24 PM
307 Chevy with 283 Chevy Pistons?? sbc307 Engine 4 10-31-2009 09:26 PM
chevy 283/327 RealGhol Engine 12 05-06-2004 05:46 PM
Chevy 283 d_67_camaro Engine 1 12-03-2002 11:46 AM
Chevy 283 51HenryJ Engine 7 10-06-2002 02:57 PM
