chevy 409 Harmonic Balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2018, 06:10 PM
hi guys hope someone can help I replaced the Harmonic Balancer be cause when you would try to time it the mark on the balancer would be aroud 3 inchs above the timimg cover marker so I put a new one on and it dose the same thing I also put a new distributor in to. the engine is not built up it is stock if it dose have aftermarket cam it is not all that maybe like an rv cam. the motor is in a 29 model a
Old 05-06-2018, 09:30 PM
vinniekq2's Avatar
Is this a brand new issue?have you verified tdc with a piston stop tool?
The Following User Says Thank You to vinniekq2 For This Useful Post:
ron29 (05-08-2018)
Old 05-06-2018, 09:35 PM
ericnova72's Avatar
More for Less Racer
Just to ne clear, you are talking about an old 409" W-head Big Block, and not a 400 small block that has been overbored .040"??
Or at you dealing with a small block Chevy??
Old 05-07-2018, 12:11 PM
X2, curious minds are awaiting this answer.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
ron29 (05-08-2018)
Old 05-07-2018, 06:50 PM
no I have not use the tdc tool yet, I have to find where to get one, and it is an original 1963 409 motor
Old 05-07-2018, 09:40 PM
Beautiful engine, like Harley Davidsons, I always thought the W motor from Chevy was work of industrial art.
Is the timing original or at least aged? Your symptoms description would have me looking at wear and stretch. Also, on the upfront list of things would be slippage of the bonded outer ring of the damper. Another high on my list would be wear or failure of the key or crank keyway.
Bogie
ron29 (05-08-2018)
Old 05-08-2018, 07:21 AM
RWENUTS's Avatar
Summit has them.
https://www.summitracing.com/int/sea...0Center%20tool
And balancer.
https://www.summitracing.com/int/sea...-size/6-7l-409
The Following User Says Thank You to RWENUTS For This Useful Post:
ron29 (05-08-2018)
Old 05-08-2018, 07:09 PM
Thanks guys for the information on that I have order a piston stop so I will chek it out this weekend to see if that will fix it I will let you know.
Old 05-13-2018, 10:34 AM
Hi guys will I got a piston stop tool and now I got the timing good car is running better I have not time it at around 3000 rpms with degree tape. but it is running good. I have never use the degree tape dose make it any better when you time it at the high rpms, I am not drag race it. just want to say thanks
Old 05-13-2018, 11:44 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Here is a good article for those of you who may have timing problems.....
http://www.crankshaftcoalition.com/w...op_dead_center
Old 05-13-2018, 12:25 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Very easy to make your own piston stop from an old spark plug and piece of round stock, just ensure the stop is securely epoxied or spot welded to the plug.
Semper Fi
Harmonic balancer on blown s/b chevy blown 52 F-1 Engine 3 12-11-2006 07:43 AM
409 Harmonic balancer y112 Engine 0 05-28-2006 12:44 PM
chevy harmonic balancer antiquebob Engine 3 03-01-2005 04:52 PM
Chevy 350 Harmonic Balancer subman17 Engine 2 08-29-2003 09:14 PM
harmonic balancer 350 chevy jimm Engine 5 03-17-2002 09:54 AM
