Chevy rear axle shaft press stud to threaded? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2019, 05:06 PM
Hi
Im rebuilding my chevy 12 bolt rear. I want to upgrade the 7/16 press stud to 14x1.5 threaded studs. I drill the axle shaft to 12,5mm but I can`t tap the shaft. Any sugestion? the axle is to hard for the tap?
thanks
Old 10-26-2019, 05:15 PM
that is really hard to tap and to keep the hole straight, unless you have a mill with a tapping head.
Consider getting some press in studs.
Old 10-27-2019, 07:58 AM
big gear head's Avatar
High Performance Rear Ends
This really should be done by a machine shop so that the bolt circle is correct and the holes are tapped straight.
Old 10-27-2019, 10:44 AM
johnsongrass1's Avatar
Race it, Don't rice it!
You need a better tap and a lot of cutting fluid like Tap Magic or Rapid Tap.
The two fluted taps area best for this.
I redrilled something similar before by using a 2”od solid dowel with a 1/2” hole down the middle.
Use it as a tap guide. I thought about welding a tab on the bottom that would run across the flange to the opposite stud hole to further aid in use but I never did. It worked out okay until both rear axles broke in a unrelated tree stump incident.
Old 10-27-2019, 11:17 AM
ericnova72's Avatar
More for Less Racer
You may need a Cobalt tap for this, which is made for tapping hard materials and hardened steels....in which case it might be just as cheap to pay a machine shop to do it....looking at probably $60+ for a Cobalt tap in Metric 14 x 1.5
Tap is listed at $65.90 at McMaster-Carr. For use on nickel and other hard materials.
Why metric 14 x 1.5??
1/2"-20 almost the exact same diameter, and the tap is almost half the cost of the metric crap.
Old 10-27-2019, 11:24 AM
Probably due to his location.
Old 10-27-2019, 12:38 PM
ericnova72's Avatar
More for Less Racer
Ahh, South America.....I missed that fact. Metric is surely easier to obtain down there!
But yeah, he is going to need a tap made specifically for hard materials.
