chevy smallblock 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2009, 10:41 PM
i heard a rumor that chevy smallblock 400s were known for blowing cranks is this true?could i get the scoop on the 400 if there worth messing around with or not.the engine would be going in a 1954 chevy truck.thanks for your time.tony
Old 02-13-2009, 11:13 PM
No that not True. We raced 400 SBC for many years and never had any failure. We also had on in our Elcamino for long time, and it mostly stock except the RV cam and Alum intake with 600 cfm carb.and never had any problems.
Old 02-14-2009, 12:54 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
The 4-bolt version of the 400 block has less webbing material in the block than the 2-bolt. Back when this motor was first introduced and hot rodders began extracting high hp numbers, they found that the webbing would pull out of the crankcase and you'd run over the crank more readily with a 4-bolt block.
Old 02-14-2009, 12:55 AM
bullheimer's Avatar
NEVER use credit cards!
havnt heard about em blowing up but my stock one out of a van moved too much inside the block on the thrust bearing and it scraped all the counterwieghts on the cradle of the block so it needs a new crank if i want to build it.
Old 02-14-2009, 06:53 AM
so your saying the 2 bolt main is better with the 400
Old 02-14-2009, 07:11 AM
SSedan64's Avatar
Yes, the 2-bolt block has thicker main webs. For more main cap strength most use the splayed 4 bolt cap conversion kits such as Milodon makes.
400 Chevy fat40 Engine 6 12-07-2006 11:00 PM
Chevy 350 to 400 trans combo Rockey Meo General Rodding Tech 5 09-14-2006 02:46 PM
Powerglide trans to 400 Chevy motor K9sicem Transmission - Rearend 3 07-09-2006 08:43 AM
chevy 400 block??? chevelle434 Engine 8 02-14-2005 12:05 PM
rebuilding my chevy 400 B-Body-MAN Engine 2 11-28-2004 08:19 PM
