Choke light issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2019, 07:09 AM
Choke light issue
Hi new to the forum. I have been on Firebird nation with this and its not resolved. I have a 1980 FB 4.9L 301. The choke light will come on and off while driving. I have not correlated it with acceleration or deceleration or any other event. It just seems to come on for a min or two then go off for a few min.
I put on a new Alt. on advice from FBN. They said the diodes go out and the car sat for 35 years on a garage stuck in a trust. So it had to go to a shop to have a new AC comp. put on and I asked the guys to take a look at the choke issue.
They messed with the electric choke and then put on a new Alt. saying the one I replaced was bad. The light stayed off. I thought it was fixed.
Then I was replacing the fuel filter and noticed the electric choke wire was pulled off and tucked under it. I put some die electric grease on it and replaced it and next drive I am having the choke light go on and off again. So Two new alts and the issue is not fixed. I am wondering if it could be a bad relay? Any help appreciated thanks.
Old 11-12-2019, 10:48 AM
Did you ever replace the choke?
Old 11-12-2019, 11:51 AM
This is a commom problem on these cars, either the relay is bad or the alternator output is to dirty in tems of what the signal output.
Between what passes for quality these days for alternators and how good a 40 year old relay is, who knows? That said if you've been through the simpler but expensive alternator replacement a couple times with no improvement, you could suspect the relay.
Evidently no one in the past found the problem either. For all the stupid crap GM has done this system takes so called safety into the nonsense zone.
Bogie
