Clear coat prep - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2017, 07:29 PM
Clear coat prep
This deck lid was my first attempt at laying down chevy 'ss' stripes and overall it turned out well.. I'll admit I used Duplicolor PaintShoppe Lacquer...
my question comes in on the clear coat. I messed up and organge-peeled the clear REALLY bad. It took a ton of aggressive blocking with 400 grit to get it leveled out. judging by the color of the run off from wet sanding, I'm pretty sure I've rubbed through the clear in a couple places in the solid white.. the stripes are o.k.
i've worked up to 800 grit wet working on getting it polished back up. .will it be o.k to re-spray a few more coats of clear over the 800 grit finish?
ID:	344250   Click image for larger version
ID:	344258   Click image for larger version
Old 02-11-2017, 08:34 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
You can sand with 600 and reshoot clear without any issues 800 is ok but a little too fine for me I always wonder if the clear has enough scratch to get a good grip or if it will peel but plenty of others use 800 so it should be ok.
The Following User Says Thank You to deadbodyman For This Useful Post:
22george (02-11-2017)
DYI base coat / clear coat prep. Captn_Jim Body - Exterior 1 12-15-2016 06:57 AM
design ,stripes, wich paint base coat over spi clear coat Vincentnova Body - Exterior 1 08-12-2012 08:19 PM
Maroon scuff pad to prep clear coat 67Elcamino Body - Exterior 4 06-03-2012 11:15 AM
spraying clear coat on top of clear coat? bennecc Body - Exterior 9 05-08-2012 04:59 AM
Clear Base coat vs Clear Top coat waterdude Body - Exterior 7 12-13-2010 11:11 AM
