ClutchTamer in a '69 Camaro part II - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2018, 08:40 PM
big gear head's Avatar
High Performance Rear Ends
Last year I tried the small version of the Clutch Tamer and it didn't work out in my car. It might work in others, but wasn't the right choice for mine. I now have the full size ClutchTamer and I finally got a chance to install it this week. I wanted to show how I did it so that maybe some others might benefit from it. The universal kit comes with the cylinder, mounting bracket, clutch pedal bracket, adjustment knobs and some other parts. I didn't think to take some pictures of the kit before I started, but you can go to the ClutchTamer web sight http://clutchtamer.com/ and see it, or maybe Grant will post a picture of it.
The first thing that the instructions say to do is install a clutch pedal stop. I noticed that my clutch pedal was hitting the plastic carpet cover at the base of the steering column, so I made a stainless steel plate to fit over the plastic cover. This will be my stop for now. If I see the need for something better I'll make a stop that clamps on the pedal arm and let it hit this plate.
ID:	428857   Click image for larger version
The Following 4 Users Say Thank You to big gear head For This Useful Post:
AutoGear (06-04-2018), Crosley (06-02-2018), OneMoreTime (06-11-2018), PHWOARchild (06-04-2018)
Old 06-02-2018, 08:43 PM
The bracket that comes in the kit requires drilling a hole in the clutch pedal arm. I didn't want to do that, so I made this bracket that clamps on the arm. The instructions say that you need close to 3 inches of travel, but no more or the cylinder may be damaged. This position gave me exactly 3 inches of travel.
ID:	428873   Click image for larger version
The Following User Says Thank You to big gear head For This Useful Post:
Old 06-02-2018, 08:48 PM
I needed to mount the bracket that controls the cylinder, but I didn't want to drill or cut anything on my dash. I found some factory drilled holes that I could use and also used 2 of the bolts that hold the steering column in. I had to remove the cover that goes under the steering column, but I'm going to be removing the ClutchTamer when I'm not racing the car, so the cover will go back on when the ClutchTamer in not installed.
ID:	428889   Click image for larger version
ID:	428897   Click image for larger version
Old 06-02-2018, 08:50 PM
The kit comes with a black plastic knob, but I had to take it up a notch, so I made this knob for mine.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
AutoGear (06-04-2018), Crosley (06-11-2018)
Old 06-02-2018, 08:52 PM
After the fabrication work was done I got everything installed. I haven't had a chance to test it yet, but I think it's going to work well. It's easy to install and remove, so I can put it in and take it out whenever I need to. I'll come back when I get it adjusted and test it and let you all know how it works.
ID:	428921   Click image for larger version
Old 06-11-2018, 10:01 AM
any testing over the weekend?
Old 06-11-2018, 10:26 AM
Nope. Car show Saturday morning and bad weather after that. I've got to figure out where I'm going to do this. I need to get away from homes so nobody complains about the noise and some idiot trying to drag race.
Old 06-11-2018, 02:58 PM
...its only a drag race if there are 2 cars...its an unsafe exhibition of speed; or an inability to control the vehicle IF you are alone...or so Ive heard LOL
Im chompin' at the bit over here LOL - Don't mind me though, get to it whenever you do, its all in good fun.
Old 06-12-2018, 07:15 PM
One of my NMRA guys running Factory Stock sent me a note last nite, just got back from winning $9700 over the course of the weekend. Saturday he won $4700 in the rain delayed last couple rounds of the Maple Grove race, Sunday he took home another $5000 check for his Super Nats win. With the air, it was running 10.2's @ 129. He's running an off the shelf SPEC 10.5" diaphragm clutch with it's hit controlled by a ClutchTamer.
"DA got terrible and lost a bunch of power, with a turn of the dial I went from 1.45 60' to a 1.38"- Dan Ryntz
Grant
The Following 3 Users Say Thank You to aisr For This Useful Post:
AutoGear (06-14-2018), big gear head (06-12-2018), Crosley (07-14-2018)
Old 07-14-2018, 09:02 AM
The Car Craft Summer Nationals is next weekend. I'll be there trying to tune this thing and see how it works. I hope to have some pictures and good results to post when I get back. If any of you are there please look me up.
AutoGear (10-01-2018), Crosley (07-14-2018)
Old 09-29-2018, 09:53 PM
Here is an update on the cluchtamer. I went to Windy Hollow Raceway today. This track has been closed for about 6 years. Some people cut the bushes and weeds down that were growing in the cracks in the track and blew off as much of the dirt as possible. There was no rubber on the track at all. I think I finally got the clutchtamer dialed in pretty close because my car was lifting the left front tire and hooked up well. It didn't break the tires loose on any shifts. I don't think I would have done very well without it.
The Following 6 Users Say Thank You to big gear head For This Useful Post:
aisr (09-30-2018), AutoGear (10-01-2018), Crosley (09-29-2018), ericnova72 (09-29-2018), Gearhead Poppa (09-30-2018), OneMoreTime (10-01-2018)
Old 10-01-2018, 08:31 AM
Now thats a cool update!
Old 10-01-2018, 09:18 AM
Thanks for the feedback!
The latest trend is increasing air pressure. At Beech Bend this last weekend, some of my ClutchTamer customers were up over 20psi in their bias slicks (3100lbs) and still dead hooking.
Grant
Old 10-01-2018, 09:23 AM
Grant
Old 10-01-2018, 10:38 AM
Grant
Thats an interesting note. What about DR guys?
ClutchTamer in a '69 Camaro big gear head Transmission - Rearend 29 07-11-2017 07:45 AM
Finding 2000 camaro door part spinn Hotrodding Basics 1 10-06-2013 08:59 PM
68 GTO, what is this part? Part of the idle control for the carb?? adam83 Engine 2 10-19-2012 06:58 PM
1989 Camaro with a 1969 camaro rear will it look good??? Opinions!! nealey101585 Hotrodders' Lounge 63 06-23-2012 04:03 AM
Sturgis Camaro rally part 2 Hobis Hotrodders' Lounge 1 02-09-2012 09:22 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
