Coilover mount, bearing or bushing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2015, 06:17 AM
Sporty45's Avatar
Another question I had about coilovers is the mounting type. I see the eyelet ends have either a bearing or a bushing. Which one is better for street rods?
Old 04-07-2015, 06:46 AM
Bushing is best for street use, they give cushionning between coilovers and chassis, it is more comfortable, less vibrations, maybe even less noise, depending.
Bearings give a very solid, "hard" connection between coilover and chassis, which is really needed only in serious race situations, but not pleasant on the street. The harshness of bearings can also cause premature wear on some parts.
As for bushings, you can also choose between rubber bushings, the usual stuff used in most new cars, simple, cheap, comfortable, or polyurethane, which is harder than rubber, kind of half-way between rubber and bearings. Polyuretahne is good for a fast car, with some "spirited", lively driving, but I find it too harsh for a cruiser, or even for simple highway use.
It is also hard to prevent the polyurethane bushings from squeaking while driving, even if you grease them well...
Old 04-07-2015, 07:09 AM
Sporty45's Avatar
Thanks Wave I was kind of thinking along those lines myself, but being new to street rodding, I figured I would check with the experts!
Acceptable amount of bearing End play in the strut mount? (Video) ForceFed86 Suspension - Brakes - Steering 1 03-29-2015 02:30 PM
Bearing VS bushing roller lifters Byronski Engine 3 11-02-2013 08:50 PM
GM pilot bushing and roller bearing I.D. #'s greenmoonshine Transmission - Rearend 30 07-07-2010 07:29 AM
bushing driver- trans. pump bushing. Chevy350Sb Garage - Tools 2 10-14-2009 10:45 PM
Installing steering column bushing/bearing cboy Suspension - Brakes - Steering 2 04-04-2004 08:00 AM
