Coilover selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2015, 04:55 PM
Sporty45's Avatar
Coilover selection
I'm looking at a couple different set ups for my C4 Vette front end in my 47 Olds project and would like some opinions on my choices. The 2 that I am looking at are both from Speedway Motors. The first is a Carrera:
Carrera BKR 11-95 Front Coilover Shock Kit 450 Rate, 13.1 Inch Mounted - Speedway Motors, America's Oldest Speed Shop
The second is a QA1:
Any opinions on these 2? Which one is preferable, and why?
Thanx, Dennis
Old 04-03-2015, 11:31 PM
johnsongrass1's Avatar
Race it, Don't rice it!
QA1's are built better than Carerra in anything I've seen but not street related.
I prefer Integra. You will have to call them and they will put a package together for you. Integra has a shock with better beefier valving and oil. That's the part that goes out most often,
Old 04-04-2015, 05:27 PM
1971BB427's Avatar
I run QA1's and love them. Are you sure you want a 450 lb. spring on the front of your car? How did you come up with that number? Might be a tad heavy, and a bit firm on the ride. Unless you're running a big block heavy motor.
Old 04-04-2015, 05:42 PM
Sporty45's Avatar
My Olds weighs in around 3800 lbs. I do the math on the spring rate calculator Spring Rate Calculator « Ridetech – Tech and 450 is what I come up with. Does this sound right to you?
Old 04-05-2015, 10:25 AM
S10xGN's Avatar
Gotta love a turbo!
I went with 450# springs on the (Aldan) coilover M-II based front clip in my Maverick. It weighs ~ 2850 with an aluminum LS-1 and drives perfectly. The shop who builds the front clip wanted to sell me 550#'s, but after mentioning the aluminum engine, they relented. Seems to me you'd be looking for at least 575#'s for anything but cruises only...
Russ
Old 04-05-2015, 11:06 AM
1971BB427's Avatar
I'd be guessing with total weight, vs. front end weight.
Old 04-05-2015, 11:45 AM
Sporty45's Avatar
Not according to that spring rate calculator I posted above. When I plug in my numbers according to the calculator, it comes up with 450lbs. It will break down the front and rear bias for you if you give it the percentages of front to rear weight. I had to guess on that part of about 52% front to 48% rear.
Old 04-06-2015, 10:16 AM
1971BB427's Avatar
That's what I meant when I said I'd have to guess. I'd be guessing what percentage of your weight is front vs. rear.
Old 04-06-2015, 11:34 AM
Sporty45's Avatar
Ah, OK. So, with the weight I posted does a 450lb spring rate sound right to you?
Coilover shock help 1966g10 Suspension - Brakes - Steering 9 03-22-2015 12:35 PM
Coilover question Minor Problem Suspension - Brakes - Steering 3 09-22-2008 04:33 PM
Coilover covers vendettaautofab Suspension - Brakes - Steering 2 07-19-2008 08:59 PM
Hi I'm coilover coilover Introduce Yourself 3 07-23-2005 01:20 AM
coilover shocks jeffbilliekatbrett Suspension - Brakes - Steering 1 01-04-2002 06:41 PM
