coilover springs ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2015, 06:50 PM
LOVEMY32's Avatar
coilover springs ?
i've got coilover springs on my 32 ford. but i'm not sure what will happen if i try to ajust them? right now the ajusting nut is at the bottom of the sprind. if i turn the ajusting nut up the spring so it pushes the spring together, will that lower my car or raise it???? seams to me that it would raise the car! and what will it do to the ride? make it stiffer or smoother? i want to lower the car and make it ride smoother, but the ajusting nut is at the bottom of the spring, so there is no ajustment to lower, right?? maybe you coilover experts can fill me in on the right ajustment? Thanks Ray
Old 09-18-2015, 10:37 PM
Coil over adjustments
Hi Ray,
Having gone through a coil over installation/conversion on a MII FE in a '38 Willys but not being an expert I'll say what I found out.
The shock rod in the center of the shock outer casing tells the story on adjusting a coil over shock. The total travel of the shock as measured by movement of the shock rod needs to be measured. You then determine at what position the shock needs to be at with a loaded car, people coolers etc. The adjusting nut can move the shock rod position allowing it to be at the correct position.
The correct position for the shock is when there is 60% of available upward travel, used when a bump in the road is hit. And 40% of travel available downward travel for when the car hits a hole in the road.
When you adjust the shock so you have the 60/40 position there is no way to lower a car because the correct adjustment of the coil over shock dictates the cars distance from the roadway.
I think the only way to lower a car is to install drop spindles or other modifications to springs, shock mounts, tire diameter, etc.
You also want the shortest shock body because that allows the lowest adjustment of the shock.
Our car has a MII Fe and when purchased it rode harsh. Using cable ties on the shock rod it was apparent the shock was bottoming out on the frame of the car. The standard coil spring was too short, this was done to lower the FE.
It was then determined the coil spring was too stiff for the weight of the car, again the spring was cut very short and that causes the spring to become very stiff.
There are Hotrodders posters out here that indicated we could have installed softer coil springs to solve the problem for less $$$ but we were already down the path to coil over installation with the shocks already installed but not the coil over springs.
Being that you already have coil over shocks all you need to do is weigh the front end of your car and make sure the coil springs are the correct strength and then adjust the shocks for the 60/40 split and your car will ride fine, ours does.
Make sure you follow the coil over shock instructions when adjusting the large nuts on the coil over shocks, we installed QA1 shocks and they require special wrenches to move the nuts AND insist on using anti-seize lubricant when moving the nut. Also make sure all the weight is off the shock when adjusting. Might be best to compress the springs if you can.
Good luck,
Tim
Old 09-19-2015, 08:45 PM
LOVEMY32's Avatar
Thanks for the information Tim!!!
Ride of Springs vs Coilover Mutt's37Buick Suspension - Brakes - Steering 12 03-12-2014 12:48 AM
2-5/8" or 2,5" diameter coilover springs? staleg Suspension - Brakes - Steering 2 12-31-2012 07:25 AM
Perch Bolts to hold coilover springs? Fe Block Suspension - Brakes - Steering 1 10-29-2012 11:09 AM
IFS in 1000# heavier car Coilover or bigger springs? charlesmajor Suspension - Brakes - Steering 0 02-09-2012 07:44 PM
Hi I'm coilover coilover Introduce Yourself 3 07-23-2005 01:20 AM
