Come On Man! - Page 360 - Hot Rod Forum : Hotrodders Bulletin Board
  #5386 (permalink)
Old 06-07-2018, 07:28 AM
Originally Posted by CrashFarmer2 View Post
I can tell you from experience that the fist time you drive a car up to that top front spot it's pretty thrilling. It looks a lot further down from up there than it does from the ground.
I hope that Vette was a restoration of a piece of crap with mis-matching numbers and all. That would be heart breaking if it was a super nice unmolested car.
  #5387 (permalink)
Old 06-07-2018, 09:29 AM
CrashFarmer2's Avatar
Grillin Randy
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Chopper???
The Following User Says Thank You to CrashFarmer2 For This Useful Post:
idrivejunk (06-07-2018)
  #5388 (permalink)
Old 06-07-2018, 09:32 AM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
Chopper???
Ha! If south of the Mason-Dixon line, would it be a "Dixie Chopper"?
  #5389 (permalink)
Old 06-07-2018, 09:54 AM
Grillin Randy
Wiki Edits: 409
I think you're right!
  #5390 (permalink)
Old 06-07-2018, 10:36 AM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Chopper???
I'm seeing a How Cool Is This, rather than a C'mon Man.....
The Following User Says Thank You to 123pugsy For This Useful Post:
  #5391 (permalink)
Old 06-07-2018, 11:05 AM
LOLOLOLOLOL, makes me want to live there!
  #5392 (permalink)
Old 06-07-2018, 02:49 PM
ogre's Avatar
the 'Duracell Project'
with that springer front end on there and all that rake it would probably be hard to do a wheelie with that thing
  #5393 (permalink)
Old 06-09-2018, 08:54 PM
Friend of mine, just a chicken laying eggs amongst his oil and stuff under the bench.
The Following User Says Thank You to MARTINSR For This Useful Post:
CrashFarmer2 (06-10-2018)
  #5394 (permalink)
Old 06-12-2018, 09:33 PM
64nailhead's Avatar
Chinaman's revenge
Thank god I saved a buck on the 105mm throttle body!! Was loctited with blue 242 when installed, I guess too much heat and meth washes it off - lol.
Happened at idle after a pass waiting for a time slip, sounded like it spun a bearing, it was banging enough to scare me into trailering it home.
It definitely constituted a 'Come on man!'
ID:	430329   Click image for larger version
ID:	430337   Click image for larger version
ID:	430345   Click image for larger version
The Following 3 Users Say Thank You to 64nailhead For This Useful Post:
123pugsy (06-13-2018), CrashFarmer2 (06-13-2018), Rip VW (06-12-2018)
  #5395 (permalink)
Old 06-12-2018, 09:57 PM
whinny's Avatar
Wouldn't that rip ya nightie.
Later gator
Russ
  #5396 (permalink)
Old 06-13-2018, 05:15 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
DAMN, all that work, tearing down an engine over a tiny screw... Did it damage the ring land to where you need to replace that piston ?
Guess I was lucky. I had a 2000 Silverado that the throttle stuck right off idle and I finally traced it to the blade scraping the bore. I took it out and sanded it until it fit and put the same screws back in with no lock tight on them. Of course, it wasn't a race engine, but I drove that truck another 40,000 miles like that.
  #5397 (permalink)
Old 06-13-2018, 08:22 AM
OMG does that bring back memories!
My brother had rebuilt the motor in his 69 GS400 Skylark. A friend and I helped him get the motor in the car and we were there to take it on the first test drive! Now mind you, it had got a hot cam and this was a four speed car, WHOOO HOOOO. We got about two blocks and there was a knocking, a funky bad knocking. We pulled over on the side of the street and my buddies and I in the car looking out at my brother starring at the motor as there wasn't a hood on the car. He stood there starring for a LONG time, my buddies and I didn't know what to do. He got back in the car and drove it back to his house and started pulling it apart without saying a word.
He ended up finding a screw like that in the cylinder. He never found where it came from and figured it probably fell into the carb when the intake and carb was sitting on the garage floor for the weeks the motor was apart.
I am reminded of this many times when I go to my friend Steve's house, it was literally right in front of this house that my friend now lives in where he pulled over to stare at the motor. LOL
Hope yours goes well and you can get it back together without much work. He had to sleeve that cylinder as I remember.
64nailhead (06-14-2018)
  #5398 (permalink)
Old 06-13-2018, 10:13 AM
Grillin Randy
Wiki Edits: 409
Oh WOW! Looks like it beat around in there quite a bit. Maybe next time you'll have to go with the red?
  #5399 (permalink)
Old 06-13-2018, 10:20 AM
64nailhead's Avatar
Piston and head are fine. Filed on both, head magnafluxed and pisto/rod measured. They are back in the motor and the heads are on. I'll be setting it back in tonight. Trying to get back to the track on Friday - a week from when this happenned.
On the positive side, the pan gasket was leaking and I had to pull the motor to reseal it, so at least that's done - lol. Also checked bearings, cylinder wear and leak checked the heads. Basically a full visual inspection with the exception of the timing gears and chain.
Trying to make chicken salad from chicken poop 'ya know
Crashfarmer - went right past the red to the green loctite. Next time I'll need to drill those screws out.
The Following User Says Thank You to 64nailhead For This Useful Post:
  #5400 (permalink)
Old 06-14-2018, 11:28 AM
I had that happen from a wood screw pep boy rebuilders used to hold the air cleaner brace on carb ended up on top of piston
automotive photography, humor
Man I need some help ivanogburn General Rodding Tech 9 10-29-2013 07:00 PM
help this man out roberteucare Introduce Yourself 1 07-06-2007 12:43 AM
New Man 37 Ford Introduce Yourself 1 11-09-2005 04:21 PM
Man oh man... I wonder if I could have a hot rod that passes emissions tests? r8ptan8 Engine 20 01-07-2004 05:59 PM
man o' man.......... crazy larry Hotrodders' Lounge 2 06-11-2003 09:19 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
