Comp 981 vs Lunati 73943 valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2010, 09:12 AM
Here are the specs
Comp 981
1.250 Single with Damper
Seat Load 105#@ 1.700"
Open Load 273#@ 1.250
Coil Bind 1.150
Rate 370
[B]Lunati 73943
Seat Load 108# @1.750
Open Load 339# @ 1.250
Coil Bind 1.060
Spring Rate 462
My question is the cam I have recommends the Lunati springs because it is a Lunati cam. The heads I am looking at have the Comp 981 springs as the first option as well as 987 springs as an upgrade but it doesn't list nor do I know if the Lunati springs are available as an option. Are the springs listed above basically equal? The will be run with 1.5 rockers. Thanks for the help.
Old 12-29-2010, 09:53 AM
Lunati 60104
The cam is the Lunati Voodoo 60104 hydralic flat tappet cam.
Cam Specs are:
Advertised Duration (Int/Exh): 276/284
Duration @ .050 (Int/Exh): 233/241
Gross Valve Lift (Int/Exh): .504/.525
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2200-6400
I will be using Summit racings 1.5 aluminum roller rockers. I am building the motor to work out to a 10.17 CR 383 sbc for a fun little street/strip usage.
I am thinking the Lunati's springs will be a better choice due to the ramp rate of the lobe in this cam. Thanks for your help
Lunati or Comp Cams valve springs? staleg Engine 5 01-21-2010 04:25 PM
Ford 302 Cam Help - Comp vs Lunati sixty9santa Engine 6 07-30-2009 02:48 PM
Beehive Valve Springs From Comp Cams - Anybody Using Them? leejoy Engine 8 10-25-2007 07:51 PM
Lunati Vs. Comp Cams Silver00V6 Engine 7 07-20-2006 06:42 AM
Will stock valve springs work with a comp 268H cam? Mike_82 Engine 7 12-22-2003 03:35 PM
