contamination in my clear, what happend??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2007, 09:18 PM
I am testing a candy paint on an old hood. i sprayed the base and then the kandy. Since i am not painting in a paint booth i wanted to test a panel out and try to wetsand any junk that landed in the kandy and then clear over it. My test was to just sand part of the panel and leave the rest alone and then clear over it. I wanted to see if by sanding a panel would affect the appearnce of the finished product, compared to the area not sanded. Well I sanded the kandy with 2000 grit just enough to get the junk out and that was it. My goal wasnt to take all/any orange peal off, it was just to lightly skim the junk out. Well the I sprayed the clear and the area i sanded came out great, no issues with varied color or anything like that. But the problem i had was the area that i didnt wetsand had lots of fish eyes. Some how it seemed contaminated. I did use a W&G remover before clearing, i dont think that was it because the part that i sanded came out excellent.
I used HOK base, candy and dupont 7900 clear.
I am working on getting my garage as clean and dust free as possible and i will have lots of exhaust with a filtered intake when it comes time to paint, i am hoping i will not have to wetsand at all between the kandy and clear, but if somthing happens i want to be prepared and have an option without stopping and redoing it all over again for it to only happen again.
Does anyone have any ideas what happend? Was it because i didnt wetsand the other area too? I figure that would just cause a durability issue, not fish eyes?
Thanks in advance....
Troy
Old 01-22-2007, 09:27 PM
Sounds like solvent pop more than fisheyes, the area you sanded released more solvent with the broken surface than the area that wasn't sanded, when you shot the clear on the solvents came out and disrupted the surface. or it could be contamination but not likely if it didn't happen over the whole panel. Doing test panels a person usually rushes and ignores flash times causing more trapped solvents-at least that happens to me now and then.
Old 01-22-2007, 09:47 PM
When i sprayed the clear, the area that wasnt sanded never flowed right from the first coat. The first coat was just a little heavier than a dusting, very fast/light coat. After the firts coat i saw the fish eyes so i let it dry to the touch. 2nd and 3rd coats were full wet coats and i let it sit for 25 min between coats. About an hour after the 3rd coat was sprayed the part that i didnt sand flowed out better, but very orange peely....
The base sat over 24 hours before the kandy was sprayed and the kandy sat 40 hours till i wetsanded with 2000 grit and sprayed the clear.
I am pretty shocked this happend.
Old 01-23-2007, 06:09 AM
302 Z28's Avatar
I agree with Bob, solvent pop would be my guess. It is not uncommon to see solvent pop when re-clearing if not enough time is allowed for previous coats to gass off. BarryK solved an issue I had with solvent pop by telling me to leave the freshly sanded area in the sun for the day. You should have re sanded the whole area you were going to re-clear also.
Vince
Clear coat sandthrough oldred Body - Exterior 7 10-19-2006 08:07 AM
Problems with clear; fisheyes, never dries joewhite Body - Exterior 4 10-01-2006 07:05 AM
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 06:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 09:08 PM
