coping saw to cut intricate shapes in sheet metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2015, 09:44 PM
put up or shut up
is it possible? I'm trying to find out if they can cut sheet metal and at what gage but I can't find any information on that. I'm trying to emboss metal with a bench press and need a female and male die. The coping saw would allow me to get intricate shapes to make it worth it, but it would take a lot of time I assume IF possible.
Old 03-16-2015, 11:16 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Sheet metal nibbler should get you there.
Old 03-17-2015, 06:25 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
nibbler
I use one of these, powered with an electric drill
Page 1
Old 03-17-2015, 08:14 AM
put up or shut up
nice. Is it hard to control in a drill or do you have that jig to keep it clamped down? That demo of it looks awesome. A drill provides great rpm control as well.
Old 03-17-2015, 08:32 AM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
Cutting sheet metal
If you glue the sheet metal down to 1/4 or 1/2 inch plywood with contact cement, you can cut with an electric jig saw. This will give you stability and with ultra fine blades you can cut the tightest detail that you want.
Old 03-17-2015, 09:43 AM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Spacytracy, has an excellent idea. I restored my old Stinson airplane aluminum parts by screwing them down to plywood. I also built my bead blaster using 1/2" plywood and gluing 030 aluminum to the plywood and then cutting the pieces to shape!!
Old 03-17-2015, 12:50 PM
ogre's Avatar
the 'Duracell Project'
it's called a jewelers saw when used on metal
will fine detail show up when embossing?
Old 03-17-2015, 04:14 PM
put up or shut up
I'm not sure but I'd like to give it a try. I have doubts but regardless it would be useful to have something that can make intricate cuts when needed.
Old 03-17-2015, 04:17 PM
put up or shut up
that's a nice idea, thanks. I think an air saw would work better though and think it could work. I really like the idea of this nibbler attached to a drill the cuts it makes are incredible.
Old 03-17-2015, 06:13 PM
Rip VW's Avatar
Page 1
Just thinking out loud, How much is one of them Nibblers???
Old 03-17-2015, 09:42 PM
put up or shut up
hand nibblers also seem interesting as well. would be nice to have both! Any suggestions on hand nibblers?
Old 03-18-2015, 06:57 AM
Wiki Edits: 27
power nibbler
I have the stand that I can mount it in a vise, I am a tool junkie. with a new drill I have about $ 200 in it. I am in the middle of a big building project , lots of new cabinets. I have 10 wood routers and just ordered $ 500 of new wood working tools. for years I used an Adel hand squeezer nibbler
http://www.ebay.com/itm/like/1816143...lpid=82&chn=ps
Old 03-18-2015, 02:15 PM
spacytracy's Avatar
Fine detail cuts
Go down to your favorite woodworking store, or maybe even Harbor Freight aka china tool and buy a good variable speed jig saw with some metal cutting blades. The table surface along with the variable speed and your project glued to plywood will allow you to make precise tight cuts without vibrating your teeth out while you are doing it. I did this for years while restoring 18th century antiques with tortoise shell and brass inlays. Its the only way to do precise work quickly with the exception of water jet
The Following User Says Thank You to spacytracy For This Useful Post:
tech69 (03-18-2015)
Old 03-18-2015, 06:04 PM
Double side tape also works well for connecting the metal to base.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
Rip VW (03-20-2015)
Old 03-18-2015, 06:43 PM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
How thick are you cutting? If you are embossing you should be using .090 to .125 thick material as your pattern. Aluminum sheet will work fine and that can be cut off hand with a jigsaw very easily. It doesn't have to be glued to anything.
A decent jigsaw is going to be well worth the money if you are doing a lot of this work.
Mark
How to cut a hole in sheet metal. Tip of the day 12-30-13 MARTINSR Body - Exterior 27 01-17-2014 07:39 AM
What shapes can laminated safety glass be cut into for a windshield??? zbhover Hotrodding Basics 1 01-15-2012 04:48 PM
Tin snip suggestions on cutting straight cut in sheet metal. MARTINSR Body - Exterior 24 11-22-2010 08:51 PM
B/N HF sheet metal shear broke after 6" cut matt167 Garage - Tools 4 04-23-2010 11:37 PM
Best way to cut shapes out of 3/8 steel? HotRodMan General Rodding Tech 12 04-16-2004 05:06 AM
