The cost of re gearing a GM 8.5" 10bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2015, 09:49 PM
Last journal entry: 1979 Camaro Berlinetta
I have a 1979 Camaro with a 3.08 posi was wondering how much it would cost to have someone change it to a 4.11 thanks
Old 02-26-2015, 10:52 PM
ericnova72's Avatar
More for Less Racer
In my neck of the woods shop prices, $250-300 labor, plus the cost of the gears and any bearings or shims that might need to be changed.
I do it for $150-175 at home for the locals, shims included(I have plenty), they pay for the gears and bearings, bring beer and pizza
Maybe you can find someone working after hours to save you some dough.
Old 02-27-2015, 08:28 AM
1971BB427's Avatar
Around my area the price runs between $160-$250, plus parts.
Old 02-28-2015, 12:08 AM
BuzzLOL's Avatar
Cars, Trucks, Boats
. Where are you located? May need carrier/posi change, as well...
Old 02-28-2015, 03:02 AM
ericnova72's Avatar
More for Less Racer
With the 8.5" 10-bolt, the carrier designations/case breaks are 2.73-up(called 3 series) and 2.56-down(called 2 series), so a new carrier won't be needed in 79CamaroMatt's case, his has the 3 series already.
8.5" 10-bolt does not use a 4 series carrier like some others do, so 4 and 5 series gears fit on the 3 series carrier.
Old 02-28-2015, 08:54 AM
1971BB427's Avatar
Although I avoid using them, you can also buy a ring gear spacer to put 3-4 series gears on a 2 series carrier. Sometimes other oddball rearends will require the spacer, as the limited supply of gear sets wont be easy to find.
Old 03-03-2015, 06:52 AM
Im in Lima Ohio
camaro, differential, gearing, gears
can someone explain "soft floorpans" to me? Maybe even ballpark what it'll cost me? Bill-E-BoB Body - Exterior 13 08-30-2007 02:46 PM
what to do with this 7.5" 10bolt rear end montea Transmission - Rearend 3 02-09-2007 07:46 AM
Correct me if I'm wrong... (10bolt thread, gear swap cost/carrier compatability) killerformula Transmission - Rearend 1 05-19-2005 06:36 PM
any ideas on "cost effective" springs and lifters? 357ford Engine 3 01-12-2004 07:04 PM
What's it cost to narrow a GM 10 bolt 8.5" BradZ28 Transmission - Rearend 4 10-30-2002 07:54 PM
