Cragar SS wheels, lugs and nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2018, 09:38 PM
Fang16's Avatar
Last journal entry: Project change
I have a set or old crager ss wheels with this kind of lugs and nuts. It seems wrong to me but it does center the wheel. Is it the right lug and washer.
ID:	433001   Click image for larger version
Old 07-15-2018, 10:01 PM
ntfday's Avatar
I didn't know that Cragar made a Uni-Lug style wheel. Those washers and lugs appear to be right for those wheels
Old 07-16-2018, 05:26 AM
ProStreetRob's Avatar
RedLine Stage 4 ZL1 650rwhp
I had them on my 73 Mach One and I got to say they are a rear PITA to put on,
since the Wheel Holes are Slotted the Washers have to be in the right position to be able to get all the studs centered and the lug nuts on.
Cragar Series 08/61, they call them Multi Fit / Vari Fit
Old 07-16-2018, 05:49 AM
Fang16's Avatar
Years ago I had a set of ET mags with the offset washers but the wheels had a recess on the bolt hole that the washer set in for alignment. These wheels do not have that recess.
Old 07-17-2018, 05:21 AM
PHWOARchild's Avatar
The little plate has to match the application and there were a huge PITA to install until we started taping the plates in place from the back.
Old 07-17-2018, 10:09 AM
RWENUTS's Avatar
I put a light smear of grease on the backside of one washer to hold it in place. Only needed one.
Always started at the top stud that was straight up. Snugged the lugnut up a bit and the other four were easy to install.
Once all five were good I’d go back and remove and clean the greased one.
Old 07-19-2018, 09:54 PM
that offset washer fits a 4 1/2" or 5" bolt pattern. You need centered oval washers for a 4 3/4" bolt pattern
Jegs has the correct washers for both types https://www.jegs.com/i/Cragar/260/KN...xoC5G4QAvD_BwE
Old 07-20-2018, 07:06 AM
Fang16's Avatar
That's the info I was looking for! Couldn't find it on google.
S/s Cragar Vs All Aluminum S/s Cragar Kampr General Rodding Tech 7 11-22-2010 02:20 PM
Cragar SS wheels lugs help ???? drsergio Suspension - Brakes - Steering 4 03-28-2008 05:04 PM
Cragar ss wheels not centered-HELP!! buzzbomb General Rodding Tech 15 03-28-2008 08:14 AM
Cragar SS & Chevy Rally Wheels Questions Iceberg General Rodding Tech 1 02-01-2005 11:46 AM
painting Cragar SS wheels racer56 Body - Exterior 4 12-10-2002 05:43 AM
