Crankshaft End Float - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2019, 07:18 AM
Molon Labe's Avatar
Last journal entry: Floors
I'm getting about .003" float on my 351W crank but I can get up to .007" if I press harder in both directions. However, when I relieve the pressure the gauge comes back to .003". In other words, it seems like something (the thrust bearing?) is flexing acting like a spring. The crank spins smoothly with no effort. Is this normal?
Old 08-19-2019, 08:11 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Did you tighten the cap before seating the thrust?
Old 08-19-2019, 09:08 AM
Molon Labe's Avatar
Please define "seating the thrust."
Old 08-19-2019, 09:42 AM
Molon Labe's Avatar
Ok, I know what you mean now. No, I didn't seat the thrust. Going out to the garage to try that now.
Old 08-19-2019, 12:45 PM
Molon Labe's Avatar
I loosened the bolts on all caps and rapped the crank back and forth with a large rubber mallet. Re-torqued the bolts and nothing changed. I've disassembled everything, removed the assembly lube from everything (STP) and inspected the parts. Nothing seems out of order. The bearings fit snug on the cap and block such that I really had to tug pretty hard to pull them back out.
Old 08-19-2019, 06:59 PM
Sure sounds like something is amiss. Crank should move pretty easily with just a 8” screw driver.
You sure you have the DI set up stiff enough?
You might try removing all the caps except the thrust, leaving the upper bearings in place, and checking it again. If it’s the same I’d say the thrust is messing with ya. If it’s okay, then installing each cap one at a time along with the thrust, might give a clue as to the align hone.
If you don’t get anywhere there. Might try honing the thrust by placing both thrusts together by using a hose clamp to hold them snugly together. Lay the thrust on a flat plate and snug the hose clamp down just enough to hold it together. Rub the sides on 600 wet/dry aluminum oxide paper and WD40 or lightweight machine oil.
On the flat plate, do about 5 strokes or full figure 8’s and take note of the pattern left. If you see high spots or other irregularities I’d say the thrust is off and/or needs further attention.
The Following User Says Thank You to johnsongrass1 For This Useful Post:
Molon Labe (08-19-2019)
Old 08-19-2019, 08:00 PM
Molon Labe's Avatar
The DI was set up properly. I was wondering if the thick STP was acting like a hydraulic cushion so I cleaned the STP off the bearings and journal, cleaned the cap and block and looked for any imperfections. Found nothing. I put the bearings back in with no lube on the thrust bearing but still on the other four. I laid the crank in and with no caps on any bearings I still get about .003" but more if I press harder but it springs back to .003". It takes no effort at all to move the crank the .003". The inside of the thrust bearings measures about .003" wider than the cap and block so I'm wondering why they go on and off so hard. They could be sprung so I'm going to try putting them together and sanding them and look for high spots. Should they be so tight on the cap and saddle that I can barely pull them off with my fingers?
Old 08-19-2019, 08:29 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
I'd be taking the bearings back for an exchange. If the same thing happens with another set of bearings, I'd begin to suspect that the block has been dropped.
The Following User Says Thank You to techinspector1 For This Useful Post:
Molon Labe (08-20-2019)
Old 08-20-2019, 11:28 AM
Molon Labe's Avatar
Doing nothing differently, I laid the crank back in with no thrust bearing in the block and put the cap on with the bearing. It was perfect giving me about .0055" and no spring back. I found a very slight taper down the face of the other block side half. So, I applied the "Johnsongrass1 bearing face alignment procedure" removing about .001" from each face. All assembled again and getting .0055" with no spring back. I think I can move on.
Thanks again to everyone who responded.
The Following 4 Users Say Thank You to Molon Labe For This Useful Post:
123pugsy (08-20-2019), johnsongrass1 (08-20-2019), Rip VW (08-20-2019), techinspector1 (08-20-2019)
Old 08-20-2019, 02:09 PM
Works most of the time!
You can PM your credit card number later. Thanks!
The Following 2 Users Say Thank You to johnsongrass1 For This Useful Post:
Molon Labe (08-20-2019), techinspector1 (08-20-2019)
Old 08-20-2019, 02:53 PM
Molon Labe's Avatar
Uhhhhhhhhhhhhhh..................The check is in the mail.
crank, end float
